-   -   post a picture: aftermarket or custom induction setup (http://forums.pelicanparts.com/porsche-911-technical-forum/622635-post-picture-aftermarket-custom-induction-setup.html)
scott.k 08-02-2011 09:04 PM
Hello,
I would like to see some pictures of what people are running on their cars for induction systems. I like to see the new and creative ideas, anything and everything,
please post it!
thanks
scott
al lkosmal 08-02-2011 10:09 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/573869-my-triumph-speed-triple-project-update.html
billjam 08-03-2011 05:27 AM
Here's my current project. It is a pair of Triumph Daytona 675 triple throttle bodies on custom intake runners.
ITBs are 44mm ID. They came with injectors, fuel rails, TPS, idle stepper motors and horns and were new take-offs from a Triumph racing team who presumably put something different on their racing bikes.
I fabbed the air cleaner housings in glass and carbon fibre to suit standard size K&N air filters.
Intake runners are mandrel bent 50mm OD x 3mm wall aluminium tube.
I did consider separating the throttle bodies and mounting them all on straight runners with individual filters. If I was going to do this again, that's probably how I'd go because there was a lot of work making moulds and parts for the air cleaner housings. The bends in the outer runners also mean that the height is a little more than I really want, but I can live with it.
I am not using the Triumph injectors and fuel rails because they were too small (and plastic) so I've fitted standard 3.2 fuel rails to brackets on the runners with Bosch injectors squirting straight into the ports. Don't have a pic at hand of everything assembled, but I'm sure you get the idea.
Throttle linkage is two custom cables to a bracket at the original throttle crank.
http://forums.pelicanparts.com/uploa...1312373282.jpg
http://forums.pelicanparts.com/uploa...1312373331.jpg
http://forums.pelicanparts.com/uploa...1312373365.jpg
http://forums.pelicanparts.com/uploa...1312373416.jpg
http://forums.pelicanparts.com/uploa...1312373587.jpg
Jim2 08-03-2011 06:40 AM
Billjam, that sir is very nice work.
I'm doing something similar right now, 3.6 too. I'll have to put up a couple pics. Question for you, what length did you establish from the flange to the top of the velocity stack?
billjam 08-03-2011 07:40 AM
Thanks Jim.
I don't have final dimensions available with me and I am out of town for another day or two, so can't measure them, however I found this pic which has dimensions of runners before I cut them down to final length. I think I queried the board here to find out what the optimum length might be before I cut them.
As it turned out, I decided to make them as compact as possible and to hell with the fraction of a horsepower I might lose at seven thousand revs with the "perfect" length. :rolleyes:
I am pretty sure I cut them down so that the dimension from the top of the bend to top of pipe was about 25mm (as I have noted on pic).
I plan to cut them down about another 10mm and based on some rough measurements I did on the car a few weeks back, I might also have to use a shorter filter to fit the whole lot under a standard tail with a/c condenser.
That's my preferred outcome, however I'm not locked into that because I also have a turbo tail that I can use if I need the extra clearance. The car ('88 Carrera) will also be growing a full set of turbo panels, but I'd prefer to keep it tail-less if I can.
http://forums.pelicanparts.com/uploa...1312381974.jpg
scott.k 08-03-2011 09:56 PM
thats awesome work there on both the setups, very innovative. it motivates me to work on mine when I feel lazy.
-thanks
scott
al lkosmal 08-03-2011 10:19 PM
Bill,
Wow....the level of thought and craftsmanship that went into your setup is amazing! You have mad skills.
Regards,
al
