1980SCMan
Alan Lindquist's Avatar
Help with Chain Tensioner Inspection
I'm pulling the motor tomorrow - 1980 SC. I'm going after the five or six common oil leaks and then adjusting valves. While I'm replacing my chain cover gaskets, is there a simple inspection I can do to judge the health of the chain tensioner system?
The motor has 220K miles on it and at some point before 121K it was upgraded with the Carrera oiling mod.
I'm not experiencing any issues with the current set-up or expected wear and tear, but is there a visual or mechanical inspection I can do to judge if I have a pending problem in the near future?
Old 08-04-2011, 12:36 PM
Look at the chain and the chain tensioner. If the chain is riding too close to the edge of the case, and the tensioner plunger is out too far, then the chain has stretched too far and you should replace it. At 200kmiles, you likely should replace the sprocket too.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-04-2011, 12:38 PM
kodioneill's Avatar
Take several good close ups ( of the sprockets tensioners and chain rails) and post them. Use macro feature and flash on the camera.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-04-2011, 01:46 PM
