LinkBack | Thread Tools |
HELP - MacGyver Fix Needed for upper fuse holder for fuel pump fuse-Simple fix needed
HELP - MacGyver Fix Needed for upper fuse holder for fuel pump fuse. I need a simple fix for the fuse holder for the fuel pump fuse.
After reading all the previous posts, it seems my fuse box may need a major over haul in the future. But in the meantime I'm looking how to fix the loose or deformed plastic seat that the upper fuse holder snaps into. The plastic hole seems loose or deformed that the accepts the metal upper upper fuse holder. So this upper fuse holder now is on a slight angle and the fuse may become loose or not seated tightly in the near future and will get me stranded at the worst time. Is there a way to get that upper fuse holder seated better and less on an angle so the fuse fits tighter. I've bent up the lower holder, but I don't feel that the connections will remain tight to the upper and lower fuse ends. Any advice will be greatly appreciated. I know there must be a MacGyver out there Thanks ! |
In a word... DUCT TAPE...ok, maybe two words
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Driver
Zip ties?
Is this what's going on?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Maybe just jumper something from these guys in place of the current fuse: Fuse Holder | ATO/ATC Fuse Holder | In Line Fuse Holder | ATO Fuse Block | Wholesale Fuse Holders
Something like this?
need a picture
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
![]() I picked this up from Radio Shack and used it for about a week before replacing the fuse holder block.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Thanks guys for being so helpful.
This seems to be such a common problem. You know what they say "Misery Loves Company". |
