redridge's Avatar
Stone Gaurd?
What is the proper way to put a stone guard? Do you put it over the TB cover in one piece and cover everything up. Or do you cut it where the seals are and TB cover so that you can remove the TB cover without messing with the stone guard. TIA!
Old 08-05-2011, 06:17 PM
Cooper911SC's Avatar
The narrow body cars have a cut out. The Turbo cars cover the TB.
Kind of weird but that's how they were installed.
Cooper
Old 08-05-2011, 06:31 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Mine is in one piece and covers the TB cover. When I need to re-index, I just peel it back and remove the TB cover, once work is complete, I just replace the cover and stick it back on.
The ends tore a bit, but no problem the rubber rocker trim slides right over it and hide the little tears.
Jim
'85 Carrera Targa
PCA/POC
Old 08-05-2011, 09:57 PM
