Randy Webb's Avatar
metal can accelerator cable linkage
where on the cable is this improved part located?
is it in the engine compartment?
in front of the rear wheel?
somewhere inside the shift rod tunnel?
Old 02-08-2004, 05:06 PM
Spud's Avatar
On most 911's (mine is a 1971) its under the car, just outside the shifter tunnel and before the point where your pedal linkage attaches to the throttle linkage coming from the engine.
Hope this helps...
Doug
1964 356C - "Olivia"
1968 912 - Slate Grey
Old 02-08-2004, 05:11 PM
Randy Webb's Avatar
so its up near the front wheel" Thx - it's pretty dark here in winter.
Old 02-08-2004, 06:25 PM
Zeke's Avatar
NO! Under the car at the firewall (if you want to call it that). Just before the bell crank. Next to the tranny.
Old 02-08-2004, 06:28 PM
Randy Webb's Avatar
Thx -- will feel around near there.
Old 02-08-2004, 06:29 PM
Did you get the memo?
onewhippedpuppy's Avatar
The old one on mine was just a round rubber thing, new one is encased in metal. Just on the outside of the firewall, before the transmission bellcrack, driver's side. Jack up the car and look under there, you can't miss it.
‘07 Mazda RX8-8
Old 02-08-2004, 07:33 PM
