-   -   Tachometer reading in engine compartment (http://forums.pelicanparts.com/porsche-911-technical-forum/623329-tachometer-reading-engine-compartment.html)
swade 08-06-2011 06:50 PM
Is there a way to connect a second tachometer or a test tachometer in the engine compartment for tuning with a Crane XR3000 Ignition? It would be nice to be able to read RPM's accurately without looking through the back window at the dash mounted tach. I know that many instruments do not read correctly from CDI set-ups.
Thanks,
W
schumicat 08-06-2011 06:56 PM
Some good timing lights will display rpm.
DRACO A5OG 08-06-2011 07:05 PM
LM-2 as well. Yeah black tinted rear window does not help either :(
dicklague 08-06-2011 07:08 PM
get a dwell/ tach/voltmeter. hook to trigger circuit.
Sun makes a nice one.
