Tachometer reading in engine compartment
Is there a way to connect a second tachometer or a test tachometer in the engine compartment for tuning with a Crane XR3000 Ignition? It would be nice to be able to read RPM's accurately without looking through the back window at the dash mounted tach. I know that many instruments do not read correctly from CDI set-ups.
Thanks, W
-Wade 1972 Targa, nothing matching. Looking for motor 6124265 and transmission 7720299 |
Some good timing lights will display rpm.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Member 911 Anonymous
LM-2 as well. Yeah black tinted rear window does not help either
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
get a dwell/ tach/voltmeter. hook to trigger circuit.
Sun makes a nice one.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
