LinkBack | Thread Tools | Rate Thread |
Can I use Red Line CV lube on my polycarbonate Weltmeister front c-arm bushings?
I don't have the Weltmesiter lube or whatever they recommend. I have a tub of Red Line CV Grease that I heard is as good, if not better, than what's recommended for the Weltmeister front bushings.
I can't imagine what would be special about lubing plastic bushings. I used plain wheel bearing grease. I don't see how it could harm it, and wheel bearings take a lot more heat than these bushings.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Petroleum based lubes disintegrate plastics and rubber. The combination of some rubbers and plastics with standard greases make them sticky which is bad for bushings, o rings, or whatever. Generally a fully synthetic lube is best for these applications. It's not the heat that's an issue in this case it's the compatibility between the two materials.
Thanks for the reply. |
Synthetic lube on your plastic bushing should work just fine...I just did the same thing last week. I don't know how a petroleum grease will interact with plastic though.
12' GT3 18’ 991S |
That what I used. However, the benefits of any grease will quickly wear away. You should install a zirk fitting that goes through the control arm and into the bushing. You also have to carve a small grease channel in the inside of the bushing so that the grease spreads to the areas where it is needed. Others and myself have done this. I posted a couple of pics about 6 months ago when I did this. You can try a search on "zirk" fittings.
For what it worth, I amost exclusively use the RedLine CV grease, mostly because it is available around the corner from me. Some swear by it.
