polizei's Avatar
Front oil cooler and Valance on Carrera - 930s, RUF or other?
Hey Guys,
I'm interested in installing a front oil cooler in my '87 Carrera and would like some advice on a few things:
1. What are my options in changing the front valance to allow for a front oil cooler? I see that Rennspeed has a few options that work on a Carrera...
930s Factory Style Front Valance
RUF 911 Front Valance
Any others?
2. Do these valances work in conjunction with a Carrera Whale Tail? I believe the front and rear spoilers are supposed to work together.
3. Which valance accommodates the best cooling? I understand that this is a combination of cooler size, air flow and ducting capacity.
4. What is the ride clearance on these valances? I will be using this is a street/track car, so I need do want to go too low!
5. What brand and size oil cooler do you recommend?
Many thanks!
Andy - 1987 911 Carrera Coupe
Old 07-30-2011, 05:42 AM
Bill Verburg's Avatar
Originally Posted by polizei View Post
Hey Guys,
Any others?
Many thanks!
This is what a RUf 'yellowbird' front bumpercap looks like
The oil cooler is a B&B 5.5 X 2.25 X 20 this is the only cooler on the car and works well for 3.8 and 3.6 for street use
the guys w/ 3.6 and up that track this have found that they need a bigger cooler, usually 5.5 x 2.25 x 24 or 6 x 3 x24
here's a good thread documenting the 6x3x24 install
Bill Verburg
Old 07-30-2011, 06:41 AM
tkosier's Avatar
Call Dave at TRE. He fixed me really well:
1988 Carrera
Old 07-30-2011, 07:05 AM
I've got the 930S style front valence on my 84. I also fabricated a front splitter for it. The set-up works very well on the track with the 75' Carrera whaletail. I also have an elephant oil cooler in the front for the 3.6 in back.
O2 In Sully We Believe
Old 07-30-2011, 07:06 AM
polizei's Avatar
Guys - thanks for the great replies. Love the pics and how the front turned out. I will talk to the folks at Tre and ER.
Do you guys know the dimensions of the grill on the 930s versus RUF front balance?
Old 07-30-2011, 07:13 AM
The Ruf grill opening is ~24"x4"
Bill Verburg
Old 07-30-2011, 07:22 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
running this RUF replica front bumper with oil cooler in combination with ducktail.
was at lime rock and the track temperature was 139 degrees. engine temps never went over 210.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 07-30-2011, 07:24 AM
polizei's Avatar
Bill, is there a difference in grill size between Rennspeed's RUF valance that pairs up to a Carrera bumber and the full blown RUF front bumber and valance? In other words, the grill on your car looks smaller than the grill on tkosier's at the top of the thread. Perhaps it's just an illusion.
Here are the pics from Rennspeed's site. RUF valance on Carrera bumper:
RUF bumber and valance:
Old 07-30-2011, 07:43 AM
I don't know why Rennspeed calls this a Ruf
Ruff 'Yellowbird' fronts came as either a full bumper cap w/ a separate grill and lip spoiler(as seen on my silver car) or as a valance w/ an integrated lip
here is what the valance looks like, it hangs below the stock '74-89 crash bumper
The Rufs use a separate inner structure w/ grill seen here, aftermarkets won't have this separate inner piece, they will have it all integrated
Here are all the major pieces of a Ruf valance + cooler
Bill Verburg
Old 07-30-2011, 08:09 AM
tkosier's Avatar
Mine is "Kremer Style" valance that TRE developed in house. Dave and crew at TRE prepared, mounted and painted the valence/bumper and shipped to me complete. They also prepared the Sterab oil cooler and lines which I will need for a pending 3.6L conversion. Check out the wrapping paper Dave uses - guess he knew I was an Old Hippie.
1988 Carrera
Old 07-30-2011, 08:23 AM
Just measured mine for you, the opening is 21x4 OH... It's from GT Racing
Old 07-30-2011, 09:17 AM
polizei's Avatar
Mark - I really dig yours because its not as conspicuous as the others. How is the ground clearance and fitment? What size cooler did u get in there?
Tkosier - I Luke yours bcs that cooler opening looks like it would accommodate a big unit. How is the clearance on yours? And what size is the cooler?
Old 07-30-2011, 12:33 PM
tkosier's Avatar
The cooler is Setrab 172. 22" wide, 6.5" tall, 2" thick. Fits opening perfectly. Dave did have to notch the bottom lip of the bumper so there would be room.
Clearance is tight, but it fits. You can see from photo that the top 1/3 of the cooler is close to the front tub. The bottom 2/3 has pretty good flow.
Tom
1988 Carrera
Old 07-30-2011, 01:46 PM
polizei's Avatar
Thanks for the great info, guys. In reading some of the other threads on here, it sounds like ducting is a key issue to address. It seems like the ultimate solution is to remove material from the front tub and create a duct, or use ER's oil cooler duct. I'm open to this option, but I'd prefer to install a cooler, monitor the temps and then decide whether tub cutting is worthwhile.
For you guys that have the larger cooler openings in your front valance (e.g. 23.5x6.125), do you think your setup cold accommodate a 26x7x2 cooler (total dimensions)? This is an easily sourced and affordable aftermarket option, and it would only be an inch wider on each end than the large 24" B&B cooler). It seems like height would be less of an issue than width, due to the curvature of the tub and many valances, making the gap between the cooler end and the bumper narrower than in the center of the cooler. The "911 RSR Front Bumper 7″, Not Flared" from Gt-Racing (911 Bumpers — GT Racing :: Porsche Performance Parts — Page 2) looks like it would accommodate a larger cooler:
Notice how there isn't the tapering between the cooler opening and the brake duct openings, as there is with Tre's Kremer valance. This makes me think the extra width may not be an issue. Here's a could shots of the cooler I'm considering:
I appreciate your input!
Old 07-31-2011, 01:43 PM
aseem's Avatar
This is my dp11G piece that I got from dp Motorsports in Germany: Product Details
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 07-31-2011, 02:59 PM
Rex Karrs's Avatar
What do you recommend when running a front license plate?
Rex Karrs
'74 911 w/'84 3.2 & intercooled turbo
Old 07-31-2011, 03:47 PM
polizei's Avatar
Move to a state that doesn't require one That's a good question. Pennsylvania does not require a front plate, but most of our neighbors do. I've seen several non-Porsches with front plates mounted to the side of the bumper. Not a great solution for most valances is it would either cover a fog light or a brake duct. I wonder if certain states have exemptions for cars that like ours...
Old 08-01-2011, 12:11 PM
175K911's Avatar
Illinois requires front plated, but my 911 has never had one. Neither does my X5. I had a City of Chicago cop give me a hard time once with my 528 at O'Hare airport, but that was it so now when I park at the airport I put the plate on my dashboard.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-01-2011, 12:19 PM
Flat Six
Flat Six's Avatar
Originally Posted by Buckterrier View Post
Great looking car, Mark. Is your navigator interpreting rally notes? Or just urging you to slow the f&*# down?
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 08-08-2011, 04:12 PM
Thanks Flat. Actually he's saying, Go Go!!!!
Old 08-09-2011, 02:13 PM
