Ride Height - How low is too low?
So for the folks running lower ride heights (Lower than euro) what tricks are you using to keep from rubbing?
My example - 84 Carrera 22/29 t-bars, Sport Bilsteins, max camber front and rear, running 17 inch Fikse 255 rear and 225 front. I am at about 24.5 in the rear and 24.25 in the front (fender to ground, I know not super accurate but close enough for comparo purposes. As it stands now I need an adjsutable bump steer kit (have rack spacers) but tie rod angles are still off. What are other folks running? http://forums.pelicanparts.com/uploa...1312918083.jpg |
Well, legally when something hangs lower than tire height. Mechanically when shocks bottom out or when the steering is compromised.
Around 23 inches or less at wheel arch to ground is where it gets iffy. |
How low is to low? When a CHP pulls you over, pulls out his billy club with a notch on it and checks to see if the center of the head light is below or above notch.
I think mine is stock. I know I've never change the ride height and the PO did not either. 25" front and 24.5" rear. Seems just right to me. I'm also running stock tire/wheel sizes. Only the sway bars are a little larger but that wouldn't contribute to a height change.
That's about euro ride height. Should be OK unless you do something stoopid like run 24s with rubber band tires....
When your front control arms are level or the inner most point is lower than the ball joint, that is to low.
You want to keep the front a-arm at an angle so that the inner bushings are higher than the ball joint. RIch |
Parker,
I have pretty much the same setup as you on my 89 including the steering rack spacers and everything is fine,even on the track... My hand does not fit between the top of the rear tire and the fender in the rear and in the front my knuckles just clear it. Your car looks perfect the way it is ! Cheers ! Phil |
"So for the folks running lower ride heights (Lower than euro) what tricks are you using to keep from rubbing?" ...16" Fuchs.... Mine is a little lower than real 'Euro'; not much though. I think your front needs to go up maybe 1/2". Just IMHO. But then I don't like 17s, but just my opinion of course. Your car looks pretty sharp (otherwise)! ;) :)
I'm at about 24.75 FR and 24.25 RR. I have no rubbing on 225/255 on 17s, though my front fenders are rolled. To combat bump steer, my front spindles are raised 3/4 of an inch with Elephant's bump steer kit. I have no bump steer at all now. The pic below is about a quarter inch higher than these measurements. It wouldn't hurt my feelings to get back up to that height.
http://forums.pelicanparts.com/uploa...1312944193.jpg |
its never too low, slammed with everything else stock, no rubbing at all. used to rub with 225's at the front now with 205's all good.
http://img190.imageshack.us/img190/5281/lown.jpg |
Now that looks low ... :)
Nice picture ! Cheers ! Phil |
Torsions are 22/28, but sways are stock.
Thank you very much.
Just my .02.. JR |
syzygy, not to be a pain in the butt, but I have another question. You say in your original post that in the picture posted above that your car sat a quarter of an inch higher, front and rear.
Was the suspension at that time as you have it now (raised spindles and 22/28 torsions) or was it stock? I ask because I'd love to get a set of Zuchs for my car and it currently sets at the ride height in your pic. Thank you. |
I think I need the bolt on bump steer kit. |
| All times are GMT -8. The time now is 03:31 PM. |
