No lube on one rear torsion bar; what now?
I just finished installing the second rear torsion bar. The new bushings are on, the spring plate and torsion bar cover are bolted and torqued down. Suddenly I realize I didn't lube my new Elephant Racing 29mm torsion bar
What's the outlook for this bar if I leave it as is?I already know what I have to do, but I just needed a place to vent. Grrrrr.
Henri '87 Carrera coupe: Venetian blue Last edited by Hendog; 08-13-2011 at 02:48 PM.. |
Okay I'm probably the least qualified to answer here, but you don want those spline getting fused- on either end- I hear the rule of thumb is never stick it in without any lube or it's gonna hurt- no lube equals ouch!! (Yes, tongue in cheek humor here and I can't believe I'm the first to get to post a smartass remark here!!!)
Member 911 Anonymous
+1, take them off and lube them. Lube them alot. If you can get high tack spray lube, get it. Do it right so you won't regret it later.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Northern Motorhead
+2 on that one ... That is one part that you don't want to install dry !
You're going to enjoy your car with the new bars ![]() Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I got 'er done a few hours later before the liquid soap dried to much on bushings.
The bar came out with the spring plate. I put the bar in the vise and adjusted the spring plate to the correct angle (25 deg). Then I pulled the spring plate off the TB. I marked the spline which was at 12 O'clock high on end of the TB. I lubed it up, put the TB in with the mark at 12 high, put the spring plate on at 25 degrees; it slipped right back in place. Then I just bolted the cover back on, followed by the rest of spring plate nuts/bolts. Wasn't as bad as I dreaded.
Henri '87 Carrera coupe: Venetian blue |
Since it's all buttoned up, I would suggest making sure that you're happy with the ride height and everything. I'd even consider waiting 2 weeks while everything settles. Then, if you like the height, you can reset it very accurately when you remove and lube the t-bar. conversely, if you need to adjust the height, you know what to do when you remove the bar.
I don't think that 2 weeks on a unlubed bar will do anything bad. You're just as likely to have to dig in there to adjust things later anyways. Edit: Nevermind! You posted while I was typing.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Yeah, much easier 2nd time around since you know what you are doing.
Now Enjoy Be prepared she will handle much differently, less roll
