new tires 94W or 96Y
I am about to get new rears for the 930 from the UK
current tires are 265/45/17 96Y Bridgstone Potenza RE050 however I can only find 255/45/17 94W Bridgstone Potenza RE050 I want to try and keep with same tire brand front/rear if possible I understand the reduction in speed - this should not be an issue But can I drop in load rating from 96- 94 or is the 94 correct anyway? Running on 10" RUF speedlines Many thanks
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
Schleprock
That load index is fine. 94 or 96 is plenty for these cars which are rather light.
Here are the specifics on the load index capacities Tire Tech Information - How to Read Speed Rating, Load Index & Service Descriptions
Kevin L '86 Carrera "Larry" |
Thanks Kevin for quick reply as going to order right now!
Thanks Ben
