-   -   SC CIS 02 Test port (http://forums.pelicanparts.com/porsche-911-technical-forum/624607-sc-cis-02-test-port.html)
j911brick 08-14-2011 10:52 AM
SC CIS 02 Test port
I did a search and couldn't find information on where the SC 02 sensor test port is. Found the spec for testing, but no help if I can't find the test port. Factory manuals are no help. I have an '80 sc and the 02 system appears to not be working. Also: how do you test temp sensor? Also: not getting a clicking from relay.
911Freak 08-14-2011 11:10 AM
I believe it is located on the left side of engine compartment, it is a round socket mounted in the metal panel next to the rear fuse/relay panel. If I had an engine compartment pic I would outline it for you
j911brick 08-14-2011 11:25 AM
OK, I found a plug with cap, and three (badly corroded) terminals. Is that it? WHich terminals do I test with?
tirwin 08-14-2011 11:39 AM
Can you describe what got you started on this to begin with? Maybe more details on your symptoms?
Reason I ask is that it is not unusual for people to disable the O2 sensor anyway. It just causes it to run in open-loop mode. Do you need to pass emissions? Otherwise, why bother? Not questioning... just curious. Mine is disconnected on my '83 SC.
j911brick 08-14-2011 12:02 PM
Customer brought the car in with high/hunting idle. Both those are fixed, AFR and timing set per spec, but car does not accelerate like it should.
Found info on dwell test. Duty cycle is 0.3%.
j911brick 08-14-2011 12:32 PM
Went back and tested the relay. The relay is bad.
j911brick 08-14-2011 02:56 PM
Since the 02 sensor wasn't working the car still ran like crap to spite the fact everything was tuned to perfection. So just for fun I decided to put in an early SC distributor. Now it runs like a scalded ape!
911Freak 08-14-2011 02:57 PM
early SC? the one with only 1 vacuum line on the dizzy pot?
j911brick 08-14-2011 03:08 PM
yep. Use the blue hose, plug the red hose.
boyt911sc 08-14-2011 05:47 PM
CIS troubleshooting..........
j911brick,
Do you operate an auto repair shop?
Tony
j911brick 08-14-2011 07:57 PM
Originally Posted by boyt911sc (Post 6196093)
j911brick,
Tony
Yes, part time.
