-   -   is this normal or has something had a meltdown in the smugglers box? (http://forums.pelicanparts.com/porsche-911-technical-forum/624787-normal-has-something-had-meltdown-smugglers-box.html)
andyt11 08-15-2011 12:51 PM
Whilst working on something entirely different I decided to open the smugglers box for the first time.
This is what I found....
http://forums.pelicanparts.com/uploa...1313437782.jpg
http://forums.pelicanparts.com/uploa...1313437806.jpg
It is soft like tar. Is it some kind of wrapping or is it the remains of a piece of plastic that got very hot indeed?
Also, what are these fuel lines running to? Pump is on the underside right?
Any info appreciated.
crustychief 08-15-2011 12:52 PM
That is normal and the "fuel lines" are your air conditioning lines. The goey stuff insulates your expansion valve for the A/C
GH85Carrera 08-15-2011 01:13 PM
That is 100% normal. Do not clean it up!
shadowjack1 08-15-2011 01:24 PM
In fact if it were mine, I would add some more to get 100% coverage.
grendiers 08-15-2011 01:34 PM
Chit, I thought it was an alien life-form!
andyt11 08-15-2011 01:39 PM
thanks very much for clearing that up. I didnt do anything with it. Do you know what the product is that is supposed to be on there? I could order some up and goop it on.
Glad its normal.
Must be a record, took 1 minute to get a straight answer there! Thanks!
andyt11 08-15-2011 01:41 PM
ok, next question.
in the top photo, you can see a black wire running out the top of the photo which contains a red/white and a green/white wire. On the end of the two wires, there are connectors with rubber boots on them. They are not connected to anything. Nor can I see what they would be attached to ?
Any thoughts?
crustychief 08-15-2011 02:02 PM
What year is the car?
crustychief 08-15-2011 02:06 PM
It could be for the relay or the temperature switch.
dshepp806 08-15-2011 02:16 PM
What is this insulation material called?
Thanks,
Doyle
crustychief 08-15-2011 02:22 PM
I think it is called "cork tape" or "a/c tar tape"
86 911 Targa 08-15-2011 02:35 PM
Expansion Valve Covering.
Press Tight Tape.
Andyt111-how about a few more close-up pics of those wires.
I checked my factory manual, and could not come up with anything.
good luck,
Gerry
andyt11 08-15-2011 04:04 PM
I'll snap another pic soon.
The car is an 88.
Thanks for naming the product. As for the wires, everything on the car works, I havn't noticed anything not working. They just look like they maybe once had a purpose.
86 911 Targa 08-15-2011 05:03 PM
The car is an 88.
There are only two wires?
steely 08-15-2011 06:10 PM
If they're hanging out in space around the steering rack, I was told they were for the alarm horn (something I don't have). Same deal, 1 pair of F spades w/ boots - but I didn't get the color.
link: http://forums.pelicanparts.com/porsche-911-technical-forum/588853-what-these-wires-pic.html
andyt11 08-15-2011 07:31 PM
Thats them. I bet thats what they are for.
Thanks all - I appreciate the quick answers.
Bob Kontak 08-15-2011 08:26 PM
It's actually called Presstite
http://www.coburns.com/Images/PDFs/vk_PT1.pdf
andyt11 08-16-2011 06:13 AM
So this stuff stops condensation forming which will eventually rust out the smugglers box?
I guess I should re apply this at some point.
johnnywishbone 08-16-2011 10:05 PM
throw it in the trash along with the rest of the air conditioning stuff. that's where the little battery goes.
crustychief 08-16-2011 10:07 PM
Unless you would rather have air conditioning.
