LinkBack | Thread Tools | Rate Thread |
is this normal or has something had a meltdown in the smugglers box?
Whilst working on something entirely different I decided to open the smugglers box for the first time.
This is what I found.... ![]() ![]() It is soft like tar. Is it some kind of wrapping or is it the remains of a piece of plastic that got very hot indeed? Also, what are these fuel lines running to? Pump is on the underside right? Any info appreciated. |
That is normal and the "fuel lines" are your air conditioning lines. The goey stuff insulates your expansion valve for the A/C
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
That is 100% normal. Do not clean it up!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
1988 Carrera
In fact if it were mine, I would add some more to get 100% coverage.
The newest of the noobs!
Chit, I thought it was an alien life-form!
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
thanks very much for clearing that up. I didnt do anything with it. Do you know what the product is that is supposed to be on there? I could order some up and goop it on.
Glad its normal. Must be a record, took 1 minute to get a straight answer there! Thanks! |
ok, next question.
in the top photo, you can see a black wire running out the top of the photo which contains a red/white and a green/white wire. On the end of the two wires, there are connectors with rubber boots on them. They are not connected to anything. Nor can I see what they would be attached to ? Any thoughts? |
What year is the car?
It could be for the relay or the temperature switch.
What is this insulation material called?
Thanks, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I think it is called "cork tape" or "a/c tar tape"
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Expansion Valve Covering.
Press Tight Tape.
Andyt111-how about a few more close-up pics of those wires. I checked my factory manual, and could not come up with anything. good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 08-15-2011 at 02:45 PM.. |
I'll snap another pic soon.
The car is an 88. Thanks for naming the product. As for the wires, everything on the car works, I havn't noticed anything not working. They just look like they maybe once had a purpose. |
There are only two wires?
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
If they're hanging out in space around the steering rack, I was told they were for the alarm horn (something I don't have). Same deal, 1 pair of F spades w/ boots - but I didn't get the color.
link: What are these wires? (pic)
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Thanks all - I appreciate the quick answers. |
Fleabit peanut monkey
So this stuff stops condensation forming which will eventually rust out the smugglers box?
I guess I should re apply this at some point. |
SAIGON 68
throw it in the trash along with the rest of the air conditioning stuff. that's where the little battery goes.
Unless you would rather have air conditioning.
