So whats really happening when the fan scrapes the housing?
I was adjusting my idle last night and heard several faint metallic ticks and at first thought it was the distributor or a fuel injector. I noticed some fresh metal scrapes in the lower left portion of my fan housing lined up in lines. I can only assume its one of several things (alternator bearing, fan blade housing bearing(?), or offset belt).
Looking closely at the belt, their is a very slight (hardly noticeable) wobble I can see watching the locking nut. Am I on target, or could this be something deeper in the housing? Suggestions? Thanks Bob 73.5T/CIS
Stahlwerks.com
I had this happen on my 3.0, had to tighten my alternator retaining nuts.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Thanks John.
I had the alternator rebuilt awhile ago. What is the procedure for getting in? That is getting the fan shroud off to get to the bolts are are they accessible thru the fan? Would it help to try the belt retensioning first? Bob |
Mine was almost rounded away and was wobbling a lot, but the fan did not touch the housing only looked and sounded funny. The pulley hole for the bolt was rounded off and a replacemt was needed...
Best of luck.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
i am with john on this one. your fan/alt is possibly installed with a "skew". you need to make sure all the nuts in back are even tightened.
poof! gone |
Can anyone provide a schematic or procedure for tightening the alternator bolts? Are they hard to reach? Do I have to remove the shroud? I never messed around in this area before.
Thanks Bob |
Senior Member
Also can be bearings going South. Worth checking as new fans are not cheap nor readily available.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Stahlwerks.com
take off the fan belt, then disconnect the fan strap. There are one or two bolts holding the shroud to the fan housing too. Fan housing and fan will come off as a unit, wires attached. Take either a 8 or 10mm (don't rememeber which) and tighten the 6 nuts in a star pattern. Might even put some loctite on them. Check to see the lock washers are in place.
Along with what John said...after removing the fan belt, spin the alternator by hand and listen for the scraping. Also, see if there is any obvious wobble in the shaft. Even new bearings can go bad.
Even a slightly bad bearing can cause the fan to scrape the shroud. Mine made that same noise one day and the next day it made a God awful screech. Hopefully an adjustment will help. Good luck Eric
Deutsche Fahrzeuge 78' 911SC 03' 325I BMW 03' KTM 450sx 05' S2000 (daughters) |
Possible causes:
(1) failing plastic retainer for back (in forward position relative to car) alternator bearing, (2) alternator bearings are failing again, (3) alternator securing bolt /nuts are loose, (4) fan hub has been damaged (incorrect use of belt tensioning shims and washers) and fan now has run out, (5) cracked fan shroud (shroud is what alternator is bolted to) - cracks can come from excessive belt tension, overtightened securing strap or band or metal fatigue (old age), (6) fan shroud is loose; check securing strap or band. Shroud and alternator must come out to address 1-5. |
I just reinstalled my fan and shroud, but haven't gotten Stinky running yet. I noticed that after I installed it, ONE of the blades was making slight contact with one of the coil mounting stud ends. Only one of the blades. I filed down the stud a little bit, and got it to spin freely.
Would it be a good idea for me to remove the belt and recheck the alternator nuts at the back of the fan (Front of car)? I think I should... I don't want to risk having it wobble and cause problems later on!
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
In the case of my 3.0 Turbo, it was a cracked fan shroud.
fan shroud was cracked on my old 86ragtop I guess by overtightening by PO?
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
The fan housing on my car was cracked because, I believe, the prior owner pinched the ground wires to the alternator between the housing and the crankcase. The pinched wires cocked the housing slightly, so the housing was not evenly supported around the perimeter and presumably distorted enough to crack. That's what I found, at least.
I installed a rebuilt alternator 4 times because i had a similar problem.
instead of using the plastic cooling vane as a spacer ,I put the nuts on first then the plastic thingy against the nuts and then more nuts to hold the cooling vane on.works great! no noise! |
Disconnect the Battery If you are going to start to remove the Alternator to check or tighten the bolts.
Look here for the Tech Article Click_Here
Fan squeal
I had a similar problem and found one fan blade had a small split which flared out right at the end. This made contact with the stationary housing. I pulled off the fan and cleaned the split. Pressed it together and used an apoxy weld. Filed smooth and bingo. Spins quiet like a champ. It looked like a small stone may have come up through the cylinder fins and dinged the blade.
