Harj1953
Phone charger/cigar lighter issue in '78 911.
This is my first post so I hope it's in the right place and I'm doing this correctly. Forgive me if not and maybe redirect me. I recently repurchased my '78 SC coupe (that's right, I regrettably sold it in '04 and fortunately was able to buy it back last July). Back in '04 I didn't worry about charging my cell phone from the car. Today it's almost a must. My USB adapter/charger seems to fit snugly in the cigar lighter but doesn't work. The lighter works so I know there's power. I've tried other chargers and although they are all similar design none work. I've read posts here about our older Porsches having lighters that are too wide and offer tips on fixing that issue but my lighter seems to be too long. Because the chargers I have seem to fit snugly I wonder if maybe they are too short? If so, does anyone recommend a charger that works well in our cars or does the lighter really need to be altered? Thanks for any help.
you are correct. The hole is bigger than the standard charger etc. I took some electrical tape and wound it around just a small portion of the charger barrel to snug it up. Works fine. Phone charger, radar power, etc. 78 SC , me too
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
Harj1953
Thanks for the reply Scott. The charger I use seems to fit into the lighter hole good enough with the spring loaded grounding prongs holding the charger in but I can't get power. I will try your suggestion and hope for the best.
The hole is a European cigar lighter. Do a search on the site for cigarette lighter and you will find several posts and how others have solved the problems.
It is usually possible to bend the metal tabs on the side of the charger out just a bit to make the plug just a bit bigger and fit tighter into the hole.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Harj1953
Another good tip. Thanks Glen!
Vintage Owner
You might have to look for longer USB adapters to reach the positive terminal in the lighter socket.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Vintage Owner
Lighter adapter
Cincinnati Microwave used to provide these with their radar detectors.
Have you thought about wiring up a stealth dedicated USB to 12V adapter under the dash? You would just need to tap into power somewhere, maybe the radio power line. You could snake it behind the knee pad and no one would be the wiser. Only concern I have would be if the power line wasn't switched, you may draw a small amount of power even when not using the charger. I think the radio in line is switched by the key, so that would be your best bet.
12V to USB |
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
definitely looks like an opportunity for an avid 3d printing enthusiast..
![]() ![]() i had the same challenge and this was my solution, worked out GREAT for me and it was super easy. 1st bought a cheap KNOB from one of our guys here. then gutted it. then bought a USB charger and data, took it apart to fit inside the KNOB i bought then wired it up, simple black wire and red wire then tapped into the power to the radio WALA..... kinda looks like it was thought through. i personally did not like the plug in type of usb into the lighter. Last edited by PRE-H20; 10-16-2020 at 09:56 AM.. |
![]() it was so easy, i did it twice ! |
couple of better shots with over all install look.
BTW NO POWER DRAW as I wired it to the accessory, so when the car is off so are the USB's. ![]() ![]()
Harj1953
Lot's of good advice here. I'm liking the dedicated 12v to USB adapter mounted stealth up under knee pad. Thanks GAJon for the info. Think I'll wire it into the radio so with power off so is the adapter. Amazon has them with dual ports in a nice black case. https://www.amazon.com/DAMAVO-YM1124-Square-Charger-Motorcycle/dp/B08DFQKSQG/ref=sr_1_7_sspa?dchild=1
What phone charger do the European Porsche drivers use?
Most probably they do not have this problem if there is an European cigar lighter phone charger. |
Formerly known as Syzygy
I took some pretty accurate measurements of mine a while back for someone here that was going to print one. Never heard how that project came out...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Harj1953
OK, I started this post, and here's my final word. I did buy a replacement lighter from Auto Zone and cut it down. That worked to keep my old charge in but the light well was still too deep for a positive contact. I found this charger on Amazon and it works great. I took out the fitting I made so the lighter is now back to stock. I did wrap a couple of lengths of plumbers tape (cut lengthwise for a neater fit) just to snug it up but otherwise, this charger works well, looks great, and has the advantage of a volt/amp readout as well.
https://www.amazon.com/gp/product/B07K2XL6VX/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 |
