Front door panel removal - help?
1988 911 Cab. I am trying to remove the front door panel to install new separate speakers. It has power door locks, and a 5.25" speaker mounted low and a ~3" speaker mounted high (stock system). I have a 5.25 replacement and will mount a small tweeter in the top spot (hopefully maintain the stock grill by cutting into the 3" speaker to mount the small tweeter to).
Anyway, I am trying to get the door panel off as I need to find the stock cross over to install my own. I got most of the screws out for the map pocket but it is hooked on something near the door lever. I got the top trip piece off as well we the bolts for the top of the door handle (used to pull the door shut) but I am stuck on where to find how to disconnect the door lever (opener) area. Something is got it hooked to the door but be darned if I can find it. Then I got the upper turn wheel for the door locks as well that I cannot figure out how to remove.
Any advice appreciated. Thx
Old 04-06-2007, 09:13 AM
drl911's Avatar
Door lock knob - Remove the round center plastic cover with a very small screwdriver. Behind the cover is a screw holding the knob on. The bigger plastic backing plate is also screwed on. Rotate it counterclockwise to unscrew it.
Good luck,
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 04-06-2007, 09:17 AM
The entire door handle should be removed. Can't tell from your posting if you have done that.
Also, with mine, the speak attaches directly to the door frame, therefore you have to pull the speaker as well.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Glad some are around on my day off
I got the door lock off (I shoulda seen that cover!).
And for the door handle, I unhooked the little lever that connects it to the door mechanism and the handle folds outward alot, and now I see 2 screws (allan) holding it to the door.
Turns out I don't need to remove the panel after all as the stock cross-over was behind the map holder and I can wire my new one in there after figuring our the wires.
thx!
Old 04-06-2007, 09:45 AM
91C2's Avatar
I am also removing my door panels to fix the power lock. How do I remove the bigger speaker? Do I need to remove this when i remove the door panel? I removed the tweeter by turning the cover counter clockwise.
Thanks,
1970 Morris Cooper S, 1973 Mini Clubman GT, 2008 BMW 135i Coupe, 2008 BMW 128i Cabriolet, 1995 BMW M3, 2016 Mazda Miata
Old 06-26-2011, 10:13 PM
91C2's Avatar
Got everything removed now what do I use to get the vapor barrier back???
Old 07-19-2011, 04:28 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The "sticky" stuff on the vapor barrier should be re-usable.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-19-2011, 04:48 PM
nineball's Avatar
it's butyl rope and should be available at any auto parts place.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 07-21-2011, 06:21 AM
91C2's Avatar
this is what i did, thanks
Old 08-18-2011, 04:30 PM
