ZF LSD for G50
Hi,
From where to get a used and if possible rebuild (with motorsport plates) or new with decent price ZF LSD for G50 (1989) . If you have one please contact me thru PM.
Thanx advance...
C 3.2 -89 25th years special edition *RUF-Look*
Old 08-18-2011, 08:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Matt Monson at Guard Transmission is a good source. He'll make sure the diff he sells you is set up properly and it will last longer than a factory diff with his improved friction discs.
Kevin L
'86 Carrera "Larry"
Old 08-18-2011, 08:52 AM
Guard Transmission it is then, a GT3 cup looks a right product for me
Old 08-18-2011, 09:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
For general street use or light track use, Matt has 993 core diffs that he reconfigures into a nice "recreational" LSD that works much better than the original, and doesn't bust your wallet. The GT3 cup is a bit overkill for a 89 3.2. But I suspect he'll sell you whatever you want?
Kevin L
'86 Carrera "Larry"
Old 08-18-2011, 09:33 AM
+1 Guard, if you're serious about needing a Limited-Slip Differential.
Jon B.
Vista, CA
Old 08-18-2011, 09:46 AM
I drive my car as often as possible at track, but its also a daily driver a summer time.. so do you think this 993 core would be ok for my use as well ?
Old 08-18-2011, 09:09 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Yes I think the reconditioned 993 diff is a good choice for your type of use
Kevin L
'86 Carrera "Larry"
Old 08-19-2011, 05:18 AM
