dtw dtw is offline
GAFB
Let's play "Name That Sound"
3.2L engine. New to me, 92k, suspected recent oil overfill. Haven't pulled the valve covers yet, so I can't rule out a loose valve or broken head stud yet. Let's hear what the brain trust thinks.
http://www.youtube.com/watch?v=emfvPkb43LY&feature=youtube_gdata_player
Old 08-18-2011, 10:41 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the Fan and AC belt if you have it and try again.
It may be the chain tensioners. Get a Stethescope from HB and listen for which side it may be coming from.
Over fill may just be a coincedense.
What Brand and Type of oil are you using?
Jim
www.youtube.com/watch?v=emfvPkb43LY&feature=player_detailpage
'85 Carrera Targa
PCA/POC
Old 08-18-2011, 11:06 PM
slodave's Avatar
You sure all the plugs are in correctly? Hard to tell, but almost sounds like it's firing on 5 cyls.
Old 08-18-2011, 11:19 PM
It looks like one of the chain tensioners to me.
Old 08-19-2011, 12:13 AM
slodave's Avatar
I can't remember what it sounded like when one of my tensioners failed. Probably a good idea to listen to each chain box with a stethoscope or at least a long stick/screwdriver - put your ear to it.
The above just sounds a bit like when I managed to miss the #3 plug with the wire, even thought it felt like a good connection. The 911 sounded and felt like a VW.
Don't run the engine too much longer, try and get the tools to diagnose all together and do as much as you can with the engine running as little as possible. Good luck!
Old 08-19-2011, 12:23 AM
I had a chain tensioner fail on my 88 3.2. It didn't sound anything like the engine in post #2. In fact, it didn't make noise until just off idle and it went away around 2000 rpm. Luckily no damage. The tensioners can be changed with the engine in the car with partial drop but it is a bit of a pita.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-19-2011, 03:27 AM
NOLAsc's Avatar
When you get that stethoscope or long screwdriver, try listening to the distributor too. Or maybe pull the cap and see if the rotor has been scraping the cap contacts.
I don't remember it being that loud before I rebuilt my dizzy, but I had a lot of play in the shaft and there was definitely a ticking sound.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 08-19-2011, 03:42 AM
Because its a Carrera, I think the biggest decision you have is weather it is rod bearing 2 or 5. Dont keep running it.
Bruce
Old 08-19-2011, 10:44 AM
Make Bruins Great Again
Por_sha911's Avatar
Besides the clacking, I'm hearing a whining that sounds like something was straining. I seriously doubt its a loose valve. I also don't think you should run it until you find the problem.
Joe
Old 08-19-2011, 10:57 AM
dtw dtw is offline
GAFB
Pelicaners,
The car is 'new to me'. The suspected overfill is my diagnosis after listening to the PO's account of "driving for a little while, then massive smoke, and poor running". This was corroborated by finding a ton of oil in the sump and tank, as well as badly oiled/fouled plugs. The video you see is me starting it up for the first time after running a compression test (passed with flying colors, all in range of 150 psi) and inspecting the drain plugs (pristine). I put in new plugs and fresh 20W50.
The noise sounds more like escaping gases from somewhere than a metallic noise, so I am tending to discount the loose valve and rod bearing possibilities. It also sounds like it is isolated to one hole, so I am also discounting chain tensioner and fan issues. My money is on head studs right now. Unfortunately, I won't be able to get back to the car until Sunday.
Don't worry, the car is not being driven right now...among other things, the throttle rod between the transmission and engine bell cranks is missing. Anybody feel like sending me one?? The car also needs a front pan job. Been almost nine years since I did that job.
Several BMWs
Old 08-19-2011, 11:31 PM
dtw dtw is offline
GAFB
So finishing up some work early this afternoon, I headed out to log some time on the new car. All head studs intact on lower 1-3. Found one loose exhaust valve, tightened that up. Pulled the alternator belt. Noise is still there, unchanged. Next up, check the lower 4-6, then upper 1-6. That'll have to wait until tomorrow.
Several BMWs
Old 08-20-2011, 02:47 PM
DUK DUK is offline
DUK's Avatar
I'm guessing a cyl. to head leak.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 08-20-2011, 03:15 PM
slodave's Avatar
Have you made sure the plug wires are seated correctly? Really can't hurt.
Old 08-20-2011, 03:27 PM
dtw dtw is offline
GAFB
Yup! Twice. Thanks Dave!
Old 08-20-2011, 04:49 PM
Virginia Rocks!
VaSteve's Avatar
Subscribed since I'm curious. Sounds like a baseball card in the spokes.
That video is like the Blair Witch Project.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 08-20-2011, 04:55 PM
dtw dtw is offline
GAFB
Midnight in my driveway
Old 08-20-2011, 05:13 PM
DUK DUK is offline
DUK's Avatar
Are all the plugs tight?
2000 & 2007 Dobies
Old 08-20-2011, 06:11 PM
pete3799's Avatar
Exhaust leak?
Pete
79 911SC RoW
Old 08-20-2011, 10:44 PM
dtw dtw is offline
GAFB
Elusive. Reinstalled all the plugs then checked firing order. Everything was correct. Checked the rest of the head studs and all the valve lash. All good. Cut open the old oil filter, perfectly normal.
Now I am working on getting to the chain cases so I can inspect the chain tensioners.
Old 08-21-2011, 07:37 PM
dtw dtw is offline
GAFB
OK, here's the list of what I've checked/done:
-reinstalled plugs (checked for cross threading on removal, no signs)
-checked firing order - OK
-checked cap/rotor - OK
-checked head studs and inspected under engine for combustion leaks - OK
-checked valve lash - OK
-checked oil filter innards - OK
-checked drain plugs - OK
-disconnected fan/alternator - OK
-checked tensioners - OK
-inspected chain ramps, sprockets, idlers - OK
Last night I had a look at the chain tensioners, they were not fully compressed at all and I could not deflect the plunger with a screwdriver and plenty of force applied downward. Based on everything above, and the fact that this sound is not really present at idle, but manifests under load, am I looking at a teardown? If so, and a rod has failed, what are the chances of the crank surviving?
Tensioner on 1-2-3 bank:
Tensioner on 4-5-6 bank:
Several BMWs
Old 08-23-2011, 11:39 AM
