good oil for 88 912?
Whats a good motor oil for the 88 911?
88 911 Coupe |
Driver
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Member 911 Anonymous
Hewh, I was like 912? '88? did I miss something? LOL
Oh my Brother, you are opening a can of worms. Check that Oil Barrel of Worms ![]() What is in her now? Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
im low on oil, i just need something good i can get at advance auto tomorrow morning-please advise...
ill research the preferred oil later, just need something to get by tomorrow morning
88 911 Coupe |
Driver
Valvoline VR-1, 20w-50. (Or heck, it's summer so the straight 50w will do.) Probably the most readily available decent oil. The Mobil 1 V-twin stuff (also 20w-50 IIRC) will also work. The rest of the oils mentioned in the link I posted above is less likely to be found in your FLAPS.
Problem is if it is Synthetic or Conventional. Should not mix the two.
But as I type I realized Brad Penn is part Synthetic. Unfortunately not available at a FLAPS In that case, get some Valvoline VR1 20w50, it is conventional or Mobil 1 20W50 Synthetic. Eitherway, may want to change the oil soon after to get a fresh start. You probably know this, but make sure you check the oil level when she is hot (1/8" over the 1st hash mark on the temp gauge or 194 degrees) and still idling and on level ground. stop lift the e-brake wait about a minute to allow the oil to settle down at idle then check the dip stick. Level must be in between the to marks.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-19-2011 at 09:51 PM.. |
Capitalist and Patriot
Hope everyone has a safe and fun weekend! Get out there and stretch the old girls legs a bit!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
+2 on the 20-50, not sure about synthetic though.
How low on oil are you? There's lots o oil in that engine... A few quarts+ won't hurt for short durations and normal driving.. Flog it, now that's a different story...
Happens more often than realized, with faulty gauges and whatnot.. Don't freak too much.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I don't think there is a problem mixing conventional and synthetic oils. After all, many off the shelf oils are a mixture of the two. Anyway, I've done it many times, with no apparent harm done. YMMV,
Don Ivey '87 Carrera Smithfield, NC Quote:
