There is no substitute
Hey Pelicans,
Unfortunately I didn't get to drive my 83 SC for most of the summer. It doesn't want to start and when It does I have to hold the throttle so it doesn't die. the other day I was trying to start the engine and nothing. Then for some reason I decided to take out the air filter and flip open (then close) the pop-off valve. After doing that, The car started...And performed normally. Any Ideas as to what it can be? The SC is at a shop now. And any input would be very appreciated! Thanks in Advance. Dave
The Hacker 96 C4S 97 C2 (Gone, but not forgotten |
You don't think it's air-box related?
You opened and closed the pop off valve (back fire valve)? Sometimes during a back fire the valve doesn't close completely the O ring may dislodge, opening and closing the valve may have seated the O ring.
yep, the back fire valve...Not sure, If it was not properly seated. Hopefully that was the problem.
Also check the valve is firmly seated in the airbox. Epoxy does tend to weaken over time. Reglue if any looseness.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
One other thing to check on the pop-off valve--was it installed correctly? The hinge should be toward the rear of the car so that when the lip pops up, it doesn't hit the sloping underside of the air filter and get stuck.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Have you guys heard of anyone having this problem? It all started after I cleaned inside the airbox with some armerall...(dumb move, don't EVER do it)
Here's an articel regarding the installation of a pop off valve Pelican Technical Article: CIS Pop Off Valve Installation
___________________________________________ 2001 Boxster S, Orient Red Current Vehicle, 1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**, 1971 911T **Sold**, 1968 912 **Sold** |
BTW, the flapper on my 75 was installed incorrectly by the PO and all the above is from personal experience. As a precaution, I'd suggest a R/R of the pop-off valve to it's correct position.
