HKZ Bob's Avatar
How does a 3.0 76 Carrara cuts of fuel push mode
Hi,
a friend of mine came by with his new baby and complained that when he limps the gas the engine is firing out of the exhaust.
He has a 3.0 76 Carrera with Bosch K-jet tronic.
Can the forum tell me how the fuel is cutted of in push mode and how can I test this function
BR
Bob
Old 08-20-2011, 09:14 AM
please decipher the above.
206 637 4071
Old 08-20-2011, 09:33 AM
HKZ Bob's Avatar
My 72 has a fuel cut off switch,
does the K jet tronic has something similar?
Old 08-20-2011, 10:53 AM
Porchcar guy's Avatar
How do you define "push mode" ?? What JW asked was valid and he usually knows what to do if given the correct information !!You need to explain what hte issue is in terms that others can understand...Just saying
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 08-20-2011, 11:31 AM
HKZ Bob's Avatar
Push mode is you are lifting the gas pedal and you have no torque applied.
the car will be pushed.\
BR
bob
Old 08-20-2011, 12:17 PM
Bob,
When a driver lifts his foot of the gas pedal the car decelerates or slows down. With no throttle applied, the engine goes back to its idle RPM's....and the car slows down ....Is this what you are saying ? Also, you said "he limps the gas the engine is firing out of the exhaust"
Do you mean the engine backfires and stumbles on deceleration when he lifts his foot off the gas pedal ?
15 year PCA member
Old 08-20-2011, 12:23 PM
HKZ Bob's Avatar
Bob,
Correct
you name it
Old 08-20-2011, 12:37 PM
not getting very far here.
206 637 4071
Old 08-20-2011, 12:44 PM
JW, I was going to say...Jump right in here.... as I certainly do not know the answer to his uniquely worded statment.
15 year PCA member
Old 08-20-2011, 12:48 PM
I'm not sure why the guy can't write, but I think he's asking what stop fuel delivery when you let off the accelerator on CIS car. It appears his buddy's is backfiring during decel.
1972 911T/S MFI Survivor
Old 08-20-2011, 12:58 PM
That is also what I think..but I am not an engine guy so have no answer...was just trying to clarify his description in a manner that is understood
15 year PCA member
Old 08-20-2011, 01:01 PM
HKZ Bob's Avatar
Entschuldigung ich Spreche besser Deutsch als Englisch, aber du oder Sie können beides nicht. Es ist immer das gleiche. Zuviel kalifornische Sonne macht die Birne weich und dann werden die CA quys beleidigend.
Danke Depp Person
Old 08-21-2011, 12:20 AM
HKZ Bob's Avatar
The German word "Schubbetrieb" ist the Germany word for the mode the Porsche is doing this problem.
I freely translated it into Push Mode. Thats incorrect.
It should say Motor Braking, Overrun Condition Trailing Throttle.
Sorry guys for this misunderstanding.
Old 08-21-2011, 12:32 AM
DanielDudley's Avatar
I think his car is backfiring when lifting the throttle. Pop pop pop, yes ?
Old 08-21-2011, 05:13 AM
My '83SC uses a deceleration valve to avoid the pop on over-run/lifting off throttle. A vacuum line attached to the distributor retards the timing when the throttle is closed. However, I don't think this feature was added to CIS until the '80's so I would guess you just live with the popping. The deceleration valve was disconnected on my car by the previous owner and I find the popping not intrusive and kind of like it actually.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 08-21-2011, 05:28 AM
HKZ Bob's Avatar
Yes it looks it is still fuelling the cylinders
Old 08-21-2011, 05:32 AM
Location: Fly heading of 221 degrees out of Sebring until you see big water.
What a bunch of gibberish...
Old 08-21-2011, 06:18 AM
HKZ Bob's Avatar
correct, you added some too.
Did you get your 28 post that way?
Old 08-21-2011, 07:06 AM
My sincere apologies - I didn't know you were a non native English speaker. How about we try a whole new thread.
Old 08-21-2011, 08:04 AM
Mr. HKZ Bob - maybe we'll get an answer on this thread:
76 3.0 backfires on decel - a litle help?
Old 08-21-2011, 08:08 AM
