Oil pressure gauge
I would like to change out the oil prssure indicator on my 71 engine from the simple green indicator to the one that shows actual pressure readings. Do I have to change out the existing oil pressure idicator/sensor on the engine itself or simply change out the dashboard gauge? Thanks.
Old 08-19-2011, 09:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Just the gauge. Easy stuff, just make sure you disconnect the battery to avoid a short when pulling the connectors from behind the gauge.
'85 Carrera Targa
PCA/POC
Old 08-19-2011, 09:53 PM
Thanks DRACO
Old 08-20-2011, 09:19 AM
RETIRED
Joe Bob's Avatar
You'll need the gauge and a matched sender. Don't go all macho on the removal. Stuff can break and it ain't cheap.
Old 08-20-2011, 09:29 AM
oil pressure gauge
It seems my 72 with a 71 engine has two oil pressure sensors - one in the right front top of the engine next to the oil thermostat which is currently connected and one in the right rear of the engine near the right side chain tensioner housing which is not connected. Which one should I replace? Thanks
Old 08-21-2011, 09:34 AM
schumicat's Avatar
I think the one next the thermostat is for the pressure warning light. the gauge uses the the other one.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-21-2011, 09:43 AM
burgermeister's Avatar
You can also get just an overlay from these guys (no affiliation)
911 Gauge module overlays
It's a fair bit cheaper.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-21-2011, 09:44 AM
6 cylinder symphony
The top picture is for the "low pressure" warning light.
The bottom picture is the oil pressure gauge sending unit. That's the gauge marked "Druck".
If you use the correct porsche gauge, all you have to do is wire the gauge and you will have a live oil pressure gauge.
If the sender still works.
Ken
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 08-21-2011, 09:45 AM
oil pressure gauge
Thanks for the posts and the "overlay" link - very helpful
Dave
Old 08-21-2011, 10:12 AM
