Gerry van's Avatar
No room for thermo fan
Hi all,
Just got my car back from the panelbeaters and need to fit a thermofan as it must have failed and PO removed it but everything's gone, stoneguard seal etc.
That's all good l can get it from our host but from other pics friends have shown me that stoneguard sits at the rear and the fan is mounted on the front of the cooler obviously blowing through it.
l can't see how the fan can fit at the front with the horns in the way, does anyone have pics or can tell me if my horns are in the right spot and does this serial number on my cooler mean it was off a 930 originally. l appreciate the help as l want to order all parts l need at once as freight is a killer.
Cheers Gerry Van
Old 08-19-2011, 10:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the mount for the Horns this will allow room enough for the fan. I used zip ties to hold the horns in place, just be careful not to bend the fan, it will bind and blow the fuse. I installed aftermarket Elephant Racing fan with thermal switch.
I would consider placing a piece of ABS plastic at the bottom so air will not flow out the bottom. You want it isolated on the cooler fins.
'85 Carrera Targa
PCA/POC
Old 08-20-2011, 12:19 AM
Gerry van's Avatar
Thanks Draco, do you have photos of this? Cheers
Old 08-20-2011, 12:58 AM
DRACO A5OG's Avatar
Here you go:
Cut to shape then just use the two bolts in your #2 pic
'85 Carrera Targa
PCA/POC
Old 08-20-2011, 01:34 AM
Gerry van's Avatar
Nice work ,that sorted that out for me thanks a lot mate, Gerry
Old 08-20-2011, 01:43 AM
