86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/C Temperature Switch
Please I.D. the mfg of this aftermarket switch,
and pm member (llangston)
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-22-2011, 09:45 AM
Roger Shultz's Avatar
It looks like a Ranco like I just replaced available from our host and others. Size wise it is like the currently available version. On the side in your pictures not shown was stamped Ranco as I recall.
Roger
Former rides
1961 356B 1600 (paid $800 for it in 1968!)
1968 912 soft window brown Targa
1980 911SC Targa triple black
Old 08-22-2011, 12:34 PM
So this is just and updated version of the OEM switch? Should it open up the compressor clutch circuit when turned to the full CCW position like the old ones did? When I check the continuity of my switch I get a closed circuit between the 2 spade connectors regardless of where the knob is positioned which is not what is supposed to happen according to the diagnostics checkout description on the Griffiths website. At the full CCW position I should get an open circuit which I do not get.
Old 08-22-2011, 01:48 PM
Roger
Roger,
Here's another pic.
This switch is about the same size as the one I replaced, however, the external configuration is a bit different.
Did you have to modify the switch housing to allow complete CCW rotation to the last dial marker?
Gerry
1986 911 Targa.
Only in L.A.:
