plumb4u2's Avatar
Please help I screwed up
I did some upgrades today which included head temp sensor upgrade (that went nice and easy), and I also installed new o2 sensor
There are two plugs on the o2 sensor, one the has two pins and the other has what looks like a spark plug socket
When I slid the rubber socket onto the male fitting the male fitting broke off
How bad did I screw up and can this be fixed
what is the purpose of this socket?
I ran the car and it seems to run fine
Justin
84 Carrera Targa
98 F-150 4x4
Old 08-24-2011, 02:50 PM
Scott R's Avatar
Happens all of the time. Cut the plug off and splice in the connector of your choice. I use a spade connector on mine currently.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-24-2011, 02:55 PM
Red Line Service
Marc Bixen's Avatar
Porsche Crest
Just one additional bit of info. This is a coaxial cable, meaning it has an outer noise suppression ground wire casing with more insulation then the enter core wire. This is the wire you want to connect to the O2 sensor. Make sure you cut the outer suppression ground back about 1" and tape or heat shrink it, if a strand of the ground contacts the core signal wire it will cause the car to run full rich. When Red Line does this repair we use bullet style connectors with the insulated female connector on the main harness and the male connector on the O2 sensor wire.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 08-24-2011, 03:14 PM
plumb4u2's Avatar
Thanks for the info guys I will work on repair tomorrow ....anymore tips on the perfect connector
Justin
84 Carrera Targa
98 F-150 4x4
Old 08-24-2011, 03:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Solder it really will and insulate with heat shink on both side, especially the DME side.
I used the water proof bullet spade set.
'85 Carrera Targa
PCA/POC
Old 08-24-2011, 03:52 PM
