| Registered User |
				This can't be good
			Hi guys - so while the 911 is still new to me and this is my first one and blah blah blah (no making more excused on my part) I just realized that the offset on my rear tires is noticeably different. That is that the drivers side rear wheel sits flush with the outer rear fender lip but the passenger side rear sits inboard of the fender by exactly one inch. Same 205/55/16 tires on either side. Same wheel diameter. Uh oh... | ||
|  08-24-2011, 06:46 AM |
| Platinum Member Join Date: Jul 2001 Location: Leave the gun. Take the cannoli.
			I once saw a car where the tire shop put both front wheels one one side, and both rears on the other.... Owner didn't notice until we got to the track.....    | ||
|  08-24-2011, 06:49 AM |
| a.k.a. G-man Join Date: Sep 2003
			it's common, don't worry about it.
				__________________ Сидеть, ложь, Переворачиваться | ||
| In maintenance phase |
			Spacer missing?
				__________________ 1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. | ||
|  08-24-2011, 06:51 AM |
| French Import |
			Stock wheels? Could it be the last tire shop removed a wheel spacer and forgot to put it back on... (you mentioned an exact 1 inch difference)???
				__________________ Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!  86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate | ||
|  08-24-2011, 06:53 AM |
| Better in Person |
			try sitting in the car and have somebody measure then.  the weight may sack the suspension down some giving more neg camber.  if not an alignment may be required to get the rear camber more consistent from side to side.
				__________________ 78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft | ||
| Registered |
			Remove both rear wheels to verify they are the same part number...  But with a 1" difference, you are likely missing a 25mm spacer.  In any stock configuration, a rear wheel will not be flush with the wheel well so you should find a spcer there.
				__________________ Chris 87 Carrera Coupe - Guards Red on black 00 Carrera Cab - White on Navy 05 Carrera S - Atlas Grey on gray 86 951 - India Red on black - Sold | ||
|  08-24-2011, 07:00 AM |
| Tim |
			Hi there It's not uncommon to have a slight difference between left and right. I had the same 'problem' once on my SC and it improved considerably after corner balance and aligment. | ||
|  08-24-2011, 07:11 AM |
			1" is more than a slight difference.... Post some pics and we will stop guessing.....
|  08-24-2011, 07:15 AM |
| Registered User |
			Camber looks the same on both sides to the naked eye. My passenger side looks like the offset to the fender lip here (nice car BTW);  My driver side is flush. I'll pull the rear wheels and check the part number and see if there is a spacer(s). Thanks. | ||
|  08-24-2011, 07:17 AM |
| Registered Join Date: Nov 2004 Location: Raleigh, NC
			Sometimes you can spot the spacer looking through the Fuch petals.
				__________________ John D. 82 911 SC Targa-Rosewood 2012 Golf TDI | ||
|  08-24-2011, 07:20 AM |
| Registered |
			A good bunch of answers! I would simply remove the Wheel that was the closest to the Fender Edge and see if there is a spacer and remove it! Most Spacers used Nowadays are Bolted to the Hub as opposed to the ones that used longer Studs. I never thought about the fact that Camber when you sit in the car could change enough to cause 1 side to go more Negative and the other side to go more Positive. It is also good that it is the Drivers side where you sit because Someone is always in that Position when the car is being driven.
				__________________ Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si | ||
|  08-24-2011, 07:22 AM |
| Registered User |
			Correction - the passenger side has more camber than the driver side. Neither side has a spacer that I can see. Still need to check the wheel part #. | ||
|  08-24-2011, 07:32 AM |
| Registered User |
			Please forgive the condition of the car - I'm addressing all of that but want to get her mechanically sorted first. Passenger side;  Driver side;   | ||
|  08-24-2011, 08:08 AM |
| Registered User Join Date: Feb 2011 Location: Bellevue, Wa
			pull both wheels, look for them to be the same (lay flat) and look for a missing wheel spacer on the pass side.
				__________________ Ed M 86' Coupe | ||
|  08-24-2011, 08:31 AM |
| Flat Six |
			A little tough to tell from the angle but doesn't look like a camber angle difference to me (as I see greater 'reveal' of tread on DS @ mid-axle compared to PS). As I look at tread pattern, 2nd block on DS looks like chevrons pointing up like this: ^^ and on PS is opposite direction, like this: VV leads me to believe that your tire on RR belongs on LF? Of course I'm assuming tires are same make . . . As others have mentioned, I'd pull all four wheels and double-check widths, back-spacing, and spacer/no spacer. HTH
				__________________ Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport | ||
| Better in Person |
			heavy camber at work, under load out of the esses at sears point...
|  08-24-2011, 09:04 AM |
| Registered User | |||
|  08-24-2011, 09:06 AM |
| Make Bruins Great Again |
			What year car? It is totally normal for there to be some difference from one side to the other but to put your mind at ease pull the wheels and check if the wheels are the same size and ET. Also look for spacers. You can roughly check the camber with a small carpenter's level. You should not have a spacer on only one side.
				__________________ -------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera | ||
|  08-24-2011, 09:10 AM |
| Registered User | Quote:
|  08-24-2011, 09:12 AM |
