What is the sensor/switch dead-center, top in the back of a Carrera engine?
In my quest of solving my Carrera bucking and surging at low-RPM's, I saw the sensor/switch in the back of my engine at the top, dead-center very back between the sheetmetal pieces that is not hooked up to anything. I don't think it has been hooked up in many years as the connector has lots of junk in it.
It has a sheath over the lead/wires on it and a 3-prong male connector on the end. It is close to the breather housing. I know it probably is not my issue but curious what it is and I cannot locate it in the PET. |
Are you sure it's not the male end of O2 sensor that is just lying in the wrong place?
No. That one has a 2 female and 1 male plug IIRC.
sensor
I think he is wondering about the sensor that is a test pick up for the dealers, it ends up near the throttle body behind the fan. it is not a performance issue.
Mike Bruns |
What is it for? Does it connect to anything or is it for dealer diagnostic equipment only?
sensor
Dealer diagnostics, does not hook to anything else
Mike Bruns |
Curious, is it another speed-reference sensor?
Excuse the dirty/oily engine. That was taken pre-rebuild........:eek:
http://forums.pelicanparts.com/uploa...1314296473.jpg |
Correct. That one in the picture is the "diagnostic" TDC sensor. It does nothing to affect the behavior of the engine
| All times are GMT -8. The time now is 05:35 PM. |
