LinkBack | Thread Tools | Rate Thread |
Chain fence eating turbo
What is the sensor/switch dead-center, top in the back of a Carrera engine?
In my quest of solving my Carrera bucking and surging at low-RPM's, I saw the sensor/switch in the back of my engine at the top, dead-center very back between the sheetmetal pieces that is not hooked up to anything. I don't think it has been hooked up in many years as the connector has lots of junk in it.
It has a sheath over the lead/wires on it and a 3-prong male connector on the end. It is close to the breather housing. I know it probably is not my issue but curious what it is and I cannot locate it in the PET.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 08-25-2011 at 05:56 AM.. |
Are you sure it's not the male end of O2 sensor that is just lying in the wrong place?
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
No. That one has a 2 female and 1 male plug IIRC.
sensor
I think he is wondering about the sensor that is a test pick up for the dealers, it ends up near the throttle body behind the fan. it is not a performance issue.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
What is it for? Does it connect to anything or is it for dealer diagnostic equipment only?
sensor
Dealer diagnostics, does not hook to anything else
Mike Bruns
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Curious, is it another speed-reference sensor?
IIRC, it's a top dead center (TDC) sensor.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Excuse the dirty/oily engine. That was taken pre-rebuild........
Schleprock
Correct. That one in the picture is the "diagnostic" TDC sensor. It does nothing to affect the behavior of the engine
Kevin L '86 Carrera "Larry" |
