930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Is there a special tool for end plugs on external front mount cooler
Trying to find out if there is a special tool to loosen and tighten the covers for the extetrnal front mount t-stat? The round covers.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-28-2011, 04:49 PM
schumicat's Avatar
I used a pipe wrench (like plumbers use) and it came off easily. some people here have instead used a large washer with one end ground flat, welded to a nut which can be turned with a wrench. If you take it off, get a new sealing ring (PElican sells) to prevent leaks when you reinstall.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-28-2011, 06:02 PM
h20cooled7's Avatar
Excellent tip, I searched for like 3 hours looking for this tool, I like the washer with the nut idea! I will chimprovise at the shop tomorrow!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-28-2011, 06:12 PM
