-   -   Correct orientation of swaybar brackets (http://forums.pelicanparts.com/porsche-911-technical-forum/627152-correct-orientation-swaybar-brackets.html)
clesch 08-29-2011 11:29 AM
I replaced all rear swaybar rubbers on my 1970 911S and didn’t realize that the sway bar brackets are not symmetric.
Here are two pictures of the drivers side of the rear sway bar, positioned as it would be mounted on the car.
http://dl.dropbox.com/u/16719/stabi1.jpghttp://dl.dropbox.com/u/16719/stabi2.jpg
Which one is correct? (note the slight bend in the new OEM bracket)
DRACO A5OG 08-29-2011 04:52 PM
Bolt on the drop links and you will see exactly where they go.
Put them on when she is on the ground, raised will give you too much load & trouble :eek:
john walker's workshop 08-29-2011 07:54 PM
the u-brackets are symmetrical. yours are just tweeked.
DRACO A5OG 08-29-2011 07:56 PM
Oh that is what he was writing about, doh!
clesch 08-29-2011 11:31 PM
I find this highly unlikely since I ordered the parts (2x 901 333 753 01) at my local Porsche Zentrum and they arrived packaged along with a couple of other parts that were completely undamaged.
The two parts are also exactly the same shape and so are the old brackets that came of the car.
Thanks, I’ve tried this but with the car on the ground, the bracket fits on in either way without much effort. I guess I’ll just bolt them on and hope to get it right.
john walker's workshop 08-30-2011 05:08 AM
:rolleyes: OK then.
Shaun @ Tru6 08-30-2011 05:19 AM
this is going to sound rude, but it probably took you more time to take pics and post than to be under the car and test fit each U-bracket. in the end, you'll find they are the same.
