-   -   Window lifter not working (http://forums.pelicanparts.com/porsche-911-technical-forum/627628-window-lifter-not-working.html)
Paco Anton 09-01-2011 09:27 AM
My driver side electrical widow lifter has stopped working (fortunately with the window raised). My first idea was that the swich was broken, so I swapped the switch with a good one but it does not work either.
Is there any other suspect besides the lifter motor?
The passenger side lifter works ok so I think it is not related to fuses/relays.
Thanks in advance!!!! SmileWavy
JohnJL 09-01-2011 10:00 AM
Check if you are getting power and ground continuity to the pins on the relative connectors. Exhaust all the simple stuff before going to more expensive stuff like the motor.
mnez 09-01-2011 10:04 AM
Mine stopped once. Turns out it was stuck. Someone pushed down on the window while I operated the switch to get it open. Put some silicon spray in the window channels and it has been fine ever since.
Paco Anton 09-02-2011 12:27 AM
Tried the "push down window while pressing the button" trick but does not work :(
Also the wires have the correct power and gound.
Time to change the motor...
Brorag 09-03-2011 12:34 PM
yup. mines apart with the door off, waiting on motor from Wayne. ck'd wiring, new switches, etc--not going back together till new motor in and tested.
