early drop link help
I need to make a pair of drop links for the front of an early car. I have the through the body sway bar, and the arms, but am missing the drops. If you have one nearby you could get your hands on easily....I could use four dimensions.
1) ID of the bushing hole 2) width of the same end 3) OD of the shaft 4) center to center of the bushing holes (length) All of these measurements are not so critical....unless I plan on using the available replacement bushings...which I do. I need to fab them up and get them off to the plater for some CAD. ![]() Thanks in advance. Speedo Last edited by speedo; 09-02-2011 at 08:01 AM.. |
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
This is from my 1973.5 911T
Ed 1973.5 T |
Ideally, drop links should be adjustable if corner balancing is an objective. Start here, then add the appropriate rod ends of choice:
MHT-M8: Turnbuckle, Hex Bar, Metric, M8 - Midwest Control Products Corp. Sherwood |
Lars
I've got a pair like Ed's from my 73 that are yours if you want them. Shoot me a PM with your mailing address and I'll drop them in the mail next week ( I'm out of town for the weekend). Joe
Joe Frantz 73 911 T |
