Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Genius? Or a disaster waiting to happen?
I've had some real issues with my main alternator/fan nut stripping. I've gone through 2 of them in the last two months. I think the threads on my alternator shaft aren't as great as they should be. However...as an emergency fix, I happened to find some internal engine parts, one of which had the correct threading and had a pinch bolt on it:
It's REALLY solid now, so I feel like it's a huge win. However...I'm concerned about the long-term effects of the centrifugal load that has now been exacerbated by the pinchbolt. Has anyone tried this...and to what avail?
Thanks!
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-04-2011, 03:45 PM
motorcop's Avatar
Exclamation
Won't that throw the balance off and eventually cause a vibration?
Old 09-04-2011, 03:55 PM
Rennch on YouTube
rennch's Avatar
That's the million dollar question, motorcop. I didn't feel it so far.
Michael O'Neal -
Old 09-04-2011, 04:02 PM
Platinum Member
dad911's Avatar
I'm no expert, but I would think the out of balance condition will accelerate the demise of the alternator bearings......
Old 09-04-2011, 04:05 PM
crustychief's Avatar
Aren't those kind of balanced to begin with? Volkswagen and Porsche use them on the front spindles. I guess the only way to find out is to run it. The wheels do not turn as fast as the fan though.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-04-2011, 04:57 PM
efhughes3's Avatar
That is plain dumb. Get a new alternator or repair the threads.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-04-2011, 05:04 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
They dont turn on the front wheels. They are attached to the spindles.. (which don't turn! )
I would think it would contribute to an out of balance condition as well.
Old 09-04-2011, 05:19 PM
Rennch on YouTube
rennch's Avatar
I think I'll get some lead tape and layer it a bit on the opposite side to balance it. But I'm tired of dealing with stripped nuts.
Michael O'Neal -
Old 09-04-2011, 05:24 PM
abit off center
cgarr's Avatar
"as an emergency fix" why not but get it fixed and don't drive around like that too much. I had coat hangers holding my exhaust on my plane to get it home once.
______________________
Craig
G2Performance
Old 09-04-2011, 05:26 PM
Rennch on YouTube
rennch's Avatar
Well, it was an emergency fix, but it seems like a better mousetrap, having the pinch bolt on there. No chance of it ever loosening or stripping.
Michael O'Neal -
Old 09-04-2011, 05:30 PM
efhughes3's Avatar
Better mousetrap for a bad part, but 99.9999% of us can safely say we have never had to concern ourselves with a fan nut. This can, and should, be fixed. This is why 944's took a nosedive in value- too much deferred maintenance.
Ed Hughes
2015 981 Cayman GTS
Old 09-04-2011, 05:54 PM
Plecostomus's Avatar
Dr Ferdinand Porsche III, PhD would frown upon this malfeasance
"It looks like a Pleco.."
Old 09-04-2011, 06:08 PM
Rennch on YouTube
rennch's Avatar
Alright...noted. Thanks for the feedback, all!
Michael O'Neal -
Old 09-04-2011, 06:10 PM
Hodgey's Avatar
...............definitely the latter.....
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 09-04-2011, 06:38 PM
Max Sluiter
Flieger's Avatar
The radius is not that large so the force won't be that great. If you had some machine to balance it you might be alright. It would be better to have something stronger than lead, though. More like welding something on there or glue since that does not warp anything.
Since it is not wide like a wheel a static balance would be fine.
Old 09-04-2011, 06:44 PM
Max Sluiter
Flieger's Avatar
It would be better if you could make a set-screw or a through-hole in the shaft and insert a pin through it like a cotter pin on a wheel bearing.
Old 09-04-2011, 06:46 PM
muck-raker
kidrock's Avatar
I cringed a little bit when I saw that.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-04-2011, 07:52 PM
abit off center
cgarr's Avatar
Me too but that's the same thing holding your front wheels on too!
Craig
G2Performance
Old 09-04-2011, 07:54 PM
genius enough to get you home in pinch, but i wouldn't run it that way after i got home. the alternator turns a lot faster than the engine. the fix is another alternator, which now come with a coarse threaded shaft/nut.
206 637 4071
Old 09-04-2011, 07:56 PM
Diss Member
Quicksilver's Avatar
It isn't spinning on the front front wheel though.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-05-2011, 05:15 AM
