85 911 will not start!
After an entire year of starting perfect including this morning, on a road trip in nice weather we pulled off the road to buy some apples. Got back in and would not turn over at all but heard the fuel pump. Apple guy gave me a push and it started right up. On gauges, every was fine. Got oil and no dash lights. Got home pulled in garage and turned off and would not start. Car was running very cool. No problems. Any thoughts besides starter motor going out all of a sudden? Is there a starter relay or fuse? Thanks, Nick
Old 09-11-2011, 06:54 PM
crustychief's Avatar
Maybe check the yellow wire on the starter? Mine fell off the starter on the bus once, same symptoms.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-11-2011, 06:57 PM
OK, I'll check it. Could you please tell me where about the starter is located?
Old 09-11-2011, 07:08 PM
schumicat's Avatar
the starter is bolted to the upper right side of the transmission. the wiring connects is on the side away from the engine. you need to safely get the rear of car on jackstands to look at it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-11-2011, 07:12 PM
Does the switch on the clutch ever go bad? What is strange is that it has been such a great starting car. It gave no hint of a problem. Battery is good. Just checked.
Old 09-11-2011, 07:16 PM
New update....I have 12.60 at the battery just sitting there. Also, when everything was quite tonight I could hear the starter click when I turned the key. Can the solenoid go out just like that? Nick
Old 09-11-2011, 09:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
While you are under her checking out the Yellow wire, Go ahead and clean the ground connection it is right in front of the Trans mounts. Even if it looks good, remove clean with Electronics contact cleaner and re-attach.
As you inspect the yellow wire, remove and clean as well and re-attach. DISCONNECT THE BATTERY WHILE DOING THIS
Check the Red Hot lead as well.
If you want to service the starter, check under my logon id I posted a tutorial on servicing the starter. Did your starter screech after start up?
Jim
As far as your dash, check the dial is not accidentally dimmed. I would consider placing a fuse on the gauge lights, a good
'85 Carrera Targa
PCA/POC
Old 09-11-2011, 11:04 PM
DRACO A5OG's Avatar
Jim
As far as your dash, check the dial is not accidentally dimmed. I would consider placing a fuse on the gauge lights, a good "better safe then sorry" easy mod.
'85 Carrera Targa
PCA/POC
Old 09-11-2011, 11:05 PM
The newest of the noobs!
grendiers's Avatar
My no-crank was the same, strong battery, start for quite a while, then nothing. Even with a battery trickle charger. After replacing starter, chassis ground, battery ground, tightening alternator belt, I finally piggy-backed a 2 gauge positive battery cable onto the starter thru the tunnel, to the battery. Left the original cable in place. My thoughts were that the alternator was not charging the battery. It's still working, fingers are crossed. Good luck.
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 09-12-2011, 06:28 AM
I'm sorry Jim, What I ment was I have no red dash lights. They all work fine. The last time it started yesterday , it started just fine. No noise, no delay. It just started fine. When I get under the car I'll check out what you told me.
I think at this point I would load test the battery, then check for a voltage drop at the starter while cranking / attempting to crank. it should not go under 11 or so volts. It could be a bad cell.
Old 09-12-2011, 07:36 AM
dead spot?
I remember years ago our 67 bug would not start because it had a dead spot in the starter. We would use a large screwdriver to arc the starter so it would move a bit. Then it would start several times. Can you do this to a 911? Nick
Old 09-12-2011, 10:01 AM
Friend of Warren
There is no clutch disconnect. Starter will turn with clutch engaged.
I agree with the others, either a bad starter, solenoid or possibly a bad ignition switch.
Kurt V
Old 09-12-2011, 10:25 AM
if you can hear the starter click then its likely not the ignition switch. In my experience thats usually the solenoid that makes the sound.
Old 09-12-2011, 10:35 AM
On an 85 DME car you should hear the DME relay click and the fuel pump run when you turn it to start.
Rick
88 Cab
Old 09-12-2011, 12:02 PM
muck-raker
kidrock's Avatar
it may just be a typical hot-start issue....do you know how old your starter is? Might be time for a new one, or you can re-freshen it using Draco's thread.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-12-2011, 07:20 PM
Send a message via Yahoo to arffmedic
I had the same issue. It wouldn't start but when push started ran fine. It was the ignition switch. Took a while to finally figure out. Hope that helps
Old 09-12-2011, 07:28 PM
Car fixed!
Today I jacked up the car and went under and took off all the wires and used contact cleaner and cleaned everything. Really filthy. Same starter for 26 years according to records. Then I got out a little hammer and smacked the starter several times. Went in the car , Turned it over and it started right up .. Several times! I know it may happen again so I will buy a new starter but it works for now. Nick
Old 09-13-2011, 03:15 PM
muck-raker
kidrock's Avatar
a light "tap" to your solenoid will do the trick....but be careful, the solenoid is surrounded by a "bakelite" material and cracks pretty easily.
That's why I asked how old your starter is. This is a common problem with our old starters, they are located close to an extreme heat source. If and when you decide to replace it, I highly recommend the "hi-torque" starters sold either by our host, or you can do a google search.
STONE
Old 09-13-2011, 08:48 PM
RETIRED
Joe Bob's Avatar
You can either replace the solenoid, the whole starter or install a hot start kit. Otherwise a BFH will be a new tool in your trunk.
Old 09-13-2011, 09:25 PM
