Need ignition key code
My kids got me one of those cool Porsche emblem keys. My only key works but is 25 years old and well worn. I hate to make a $60 copy that starts out "worn".
The key seller said I can get the original factory codes / numbers for the ignition key and he can make a perfect original cut from those numbers. Any advice on how to get the necessary code? |
Paper Member
I don't know. I'm just impressed you joined this site in 1969.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
muck-raker
I could really use this info too. My key operates everything but the lock on my glove box, because the key is just too worn down.
BTW, I'd also like the info on how to show my join date as 1969. I've only seen it done once before, and I subscribe to another site where I'd really like to piss 'em off.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
72' 911S
Subscribed! I really need this info too.
It helps if you are a contortionist. If the tag is still there, it will be on the back side of the ignition lock. You have to look up from under the dash at the lock assembly. It will be on the part that goes over to the steering column and on the part facing the dash itself.
If you are really lucky, you can read it backwards with a mirror. It's a white tag that is about 1/2 x 1" and will have 4 numbers on it. Here is a good picture of what you are looking for in this link. Never used 911 Ignition sw assembly w/ 2 keys Absent that, pull your left door handle and take it to the lock smith. Any good lock smith can pull the tumblers and know what the cuts are. Last edited by group911@aol.co; 10-19-2011 at 11:01 AM.. |
With a VIN and proof of owneraship, dealerships used to cut keys. Don't know if they do these days.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
