-   -   Help opening front trunk lid. (http://forums.pelicanparts.com/porsche-911-technical-forum/629065-help-opening-front-trunk-lid.html)
WI wide body 09-09-2011 09:08 PM
Need some ideas on how to get into the trunk when the cable for the latch has come off.
Thx in advance.
Joe Bob 09-09-2011 09:38 PM
Usually you pull the bumper and their should be some access ports.
Canada Kev 09-09-2011 09:42 PM
If you're in a 911, I don't know off the top of my head, but I believe 964s have an emergency release cable way up at the front of the fender well, behind the bumper.
porwolf 09-09-2011 10:44 PM
If it is an SC the Bentley book describes a procedure if the cable is broken: Behind the rubber molding drill a hole through the bumper in a certain place and stick a wire into it. That's what I remember seeing there.
Eddyvdw 09-09-2011 11:35 PM
It should open it self when the cable is broken. It's probably stuck because of old grease / dirt. Try to get some wd40 in and push the trunk a few times.
Porboynz 09-10-2011 01:07 AM
Try pushing down firmly and moving the lid left and right at the same time as much as you can with pressure from your hands. The latch is designed to fail open when the cable breaks.
WI wide body 09-10-2011 12:57 PM
I should have mentioned that it's a 1986 Euro version Carrera.
Thx for the info.
