wd40 vs penetrating oil, a big difference?
I'm about to remove my stock muffler and swap to a bursch
sport muffler. I tried the bolts today and they are frozen. I've got some WD-40 around the house that I'll try. If that doesn't do the trick is a penetrating oil worth trying? Is it that much better than WD-40 or just about the same?
commandant of the compound |
WD40 is not a lubricant.
WD = Water displacement Use the penetrating oil.
Mrdi 88 Carrera G50 |
Yep, the penetrating oils are different; WD-40 is a water dispersant not a penetrating oil or a good long term lubricant as it drys out to become "gummy". Aero Kroil or PB blaster are relatively inexpensive and readily available. Jim
Kroil is now available on the Interenet - do a Google search.
You'd think the Wurth pen. oil would be very good, but I have no experience with it. Pelican might have that. |
Mrdi, Jim, Randy -- Thanks for the info! Penetrating oil it is!
one thing WD-40 does do is eat rust. I use both depending on situation....
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
What do you think about CRC 5-56, it´s a penetrationg oil too.
When the 935 accelerates , the world is a far smaller place. 935/78 Moby Dick The project 911 page: http://project911.luminasweden.com/ |
Bland
WD 40 is great to spray in a distributor that is plagued with condensation. WD40 is not a lubricant, if you ever want to ruin an alternator in about a day, spray some WD40 on the bearings.
WD 40 not only displaces water but it also displaces whatever lubricants are there too.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Binge User
Paul |
Can I find AeroKroil at a retail store (e.g. Home Depot, Autozone), or must it be purchased online?
Only three things of this sort work:
- Kroil - PB blaster - Wurth Rost Off! BTW...you're gonna need "heat"...like cherry red ......for your project oxy/acetylene.... --Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Detached Member
Besides the oils, if you can't get the nuts off, the Sear "Bolt Out" sockets as advertised on TV by Bob Veila, really do work at getting off rounded nuts. They're sockets with internal biting teeth. You'll need new nuts/bolts, but they really do work.
Hugh |
Forgive my ignorance, but can you be more specific? If you mean that I'm gonna have to "cut" it out with a torch... I hope you're wrong!
commandant of the compound Last edited by aways; 08-20-2004 at 11:17 AM.. |
19 years and 17k posts...
PBlaster has worked for me!!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
never seen Kroil in a retail store
pb blaster stinks incredibly the heat breaks corrosion loose (or burns it to carbon & trace elements) -- unfortunately it also messes up the temper of all the metals involved wd40 might help get a nut off if not stuck much, i'd just keep a pen. oil on hand tho. |
There some products on the market that are private labeled and out perform water displacement and penetrating oils combined. I have used every brand of both and there is no comparison to the products sold by WURTH and Kimball Midwest. The trouble is finding someone to purchase them through.
There a guy on YouTube that tests all kind of oils, chemicals, lubes, greases etc. He is independent and is not paid or supported by any company. He does extensive real world testing usually with the top 10 or so best known brands of whatever he is looking at.
The one I remember best was when he tested penetrating oils. The winner surprised me. I use it almost exclusively now for breaking loose tough nuts and bolts. Found it: https://youtu.be/xUEob2oAKVs?si=P8CydH019bVEvbwK |
If oils/heat fails - air chisel to cut the nut then replace with a new one.
At the shop, time is money - ;>)
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
So disappointing to see AeroKroil finish last, been told for years how great this stuff is. This thread is 20 years old.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 12-30-2023 at 08:15 AM.. |
Wow, this is a resurrected thread, as Walt says. .
