'80 911SC
1980 911SC a/c condensor
How much clearance should there be with the a/c condenser when the engine lid is closed. I opened it today and the condenser had a hole in it from hitting the ignition coil and there is wear on the heater hose that sits just behind the fan. The cooling fins are also mashed by the heater hose.
I found that I am missing a mounting bolt on the left bracket and the foam is missing on the center bracket. are these two things really enough to give the proper clearance or is there something else that isnt right? It seems like the condenser doesn't move that much when I line them up to their proper position. |
SC rear condenser........
Not much clearance there even with everything bolted into place! The condenser that came in my SC had a mashed spot for the same reasons. I just put a new condenser in my car, making certain that all of the mounting bolts were in place. Now the lid will close without the condenser hitting anything but it's very, very close! You could add a wing and move the condenser up into the wing area. That way you would have room for a cooling fan or two.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
I removed mine.....it hit the coil,heater hose and also the compressor.
I've got an aftermarket tail (early turbo) on it. Can't believe that some are able to fit a fan on theirs.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Throw it on the ground!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
