Northern Motorhead
wildcat077's Avatar
Transmission or clutch problem,89 911
Hey guys,
Just got home from a two day track event and on my last session when i tried to downshift from fourth to third my shifter locked up in the neutral position ...
I managed to coast off the track in a safe position and the car would simply not shift anymore.
After turning off the engine i managed to get it in reverse then second gear which i used to get back to the paddock area after restarting the car.
Eventually the shifter managed to go through all the gears with the car off but if i push in the clutch when in first gear and start the car it lurches forward even with the clutch fully depressed ...
There was a burnt rubber smell when i got to the paddocks and i'm just wondering if it's my 22 year old original clutch that finally gave up after 15 aggressive track days this season ???
I was planning on doing an engine drop over the Winter but i still have a few more track weekends before putting my car away.
Hoping for an easy fix but i won't hold my breath ...
Does anybody have any suggestions where to start looking ?
Drove home with my buddie's 996 C4S while we put my car on his trailer,i have to admit that 320 stock horsepower and the short shifter throw is pretty nice ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-16-2011, 03:58 PM
loose nut behind wheel
cudabnu's Avatar
I fixed one for a friend that would grind when trying to put it into gear with the clutch pushed in (fine when not running) ended up being the PP was cracked.
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 09-16-2011, 04:07 PM
Peter Zimmermann's Avatar
It sounds like a clutch-related problem. Only an engine drop will tell the story, but the rubber hub of the disc probably failed.
Keep the Shiny Side UP!
Pete Z.
Old 09-16-2011, 04:14 PM
Northern Motorhead
wildcat077's Avatar
Peter,
That's what in was thinking as well but is there a way to diagnose this without doing an engine drop first ?
I'm not intimidated by my first engine drop,just wasn't in the immediate plans ...
Cheers !
Phil
Cheers
Phil
Old 09-16-2011, 05:01 PM
