QT alignment
Has anyone tried this system?
QT Camber/Caster Alignment » quicktrickalignment.com - Drive Fast & Carry a Big Quicktrick Stick I have not been able to find anything for alignment locally except the dealer that wants $200+...this system seems simpler that the strings and cheaper than other Caster/Camber systems plus you also get toe measurement. |
Looks like one of many similar systems...
We set up the cars on the alignment machine, and use something like this/camber plates/etc, to refine the alignment at the track if needed... Drop the coin and get the car set up and squared on pro set up. BTW $200 is not unreasonable for a four wheel alignment on a 911 |
I can buy two of these for what the dealer wants. Is there any advantage to using those expensive laser machines? I can set the toe and caster/camber with this what else is needed?
| All times are GMT -8. The time now is 07:48 AM. |
