DG624's Avatar
QT alignment
Has anyone tried this system?
QT Camber/Caster Alignment » quicktrickalignment.com - Drive Fast & Carry a Big Quicktrick Stick
I have not been able to find anything for alignment locally except the dealer that wants $200+...this system seems simpler that the strings and cheaper than other Caster/Camber systems plus you also get toe measurement.
Old 09-13-2011, 05:55 PM
Navin Johnson
TimT's Avatar
Looks like one of many similar systems...
We set up the cars on the alignment machine, and use something like this/camber plates/etc, to refine the alignment at the track if needed...
Drop the coin and get the car set up and squared on pro set up. BTW $200 is not unreasonable for a four wheel alignment on a 911
'69 911 GT-5
'75 914 GT-3
and others
Old 09-13-2011, 07:05 PM
DG624's Avatar
I can buy two of these for what the dealer wants. Is there any advantage to using those expensive laser machines? I can set the toe and caster/camber with this what else is needed?
Old 09-15-2011, 02:31 PM
