Fuel Gauge Issue
Fuel gauge is pegged at full if connected to tank gauge or not. Any ideas or previous experience? TIA Jim
Old 09-14-2011, 02:57 PM
crustychief's Avatar
It may be a bad ground or a bad sending unit. How does your oil level gauge read?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-14-2011, 03:14 PM
Gauge is pegged full whether or not it is connected to sending unit, oil gauge is ok.
Old 09-14-2011, 03:16 PM
My vote is bad sending unit. Just for a quick check, unplug the sending unit and measure the resistance between the sending unit terminals and ground.
Old 09-14-2011, 04:05 PM
Again, the gauge is pegged even when disconnected from sending unit on fuel tank, so that elminates the sending unit. Correct? Gauges were rebuilt, wiring connections to gauge checked, at a loss right now as to what the problem could be. Thought about disassembling the connector to see if there could be a short in it. Just putting the question out there to see if anyone has had this problem. Jim
Old 09-14-2011, 04:44 PM
FWIW, my fuel gauge will occasionally peg to the full mark, a tap on the glass usually frees the needle. Dunno if that's your issue as your gauges have been rebuilt, but it works for me.
Old 09-14-2011, 05:34 PM
My bad, There has been some shorts identified inside the gauge itself. I had a new one like that. I can't find the thread right now that has pictures.
Old 09-14-2011, 05:44 PM
Fuel gauge stays at half-full
Old 09-14-2011, 05:47 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the connector behind the gauge itself, becarefull not to short it on metal. I bet it is the ground. even if it looks good clean all contacts and squeeze the contacts so they will fit snugly.
If that does not work, try to re-flow the solder joints. This cured my stuck gauge.
'85 Carrera Targa
PCA/POC
Old 09-14-2011, 06:34 PM
Appreciate the input, will try all. Jim
Old 09-15-2011, 04:05 AM
