tanmanbgoh's Avatar
horn works,sometimes
I know electricial probs are almost impossible to fiqure on forum,but heres prob.. Horn will work about 50% of time. It will work all day as I pull in garage,then in morning it wont. It will come and go as Im driving, Ive had new ignition switch put in that cured headlights and speeedo,but horn is unpredictable..thanks.any ideas?
1985 Targa 3.2 Black on black,16"Fuch,23 years California car.
Old 09-15-2011, 04:16 PM
RETIRED
Joe Bob's Avatar
horn works,sometimes, watch for finger!
Pull the pad and look for worn parts......
2012 ML350 3.0 Turbo Diesel
Old 09-15-2011, 04:54 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, Wiper Switch aka Horn Switch. You can re-tension the switch to make a better contact with the copper ring on the steering wheel but in doing that you may create a scratchy noise.
Emory cloth the edge of the ring and it will lesson the chance of creating the noise.
Place some di-electric grease after adjustment/polishing.
'85 Carrera Targa
PCA/POC
Old 09-15-2011, 07:58 PM
the ground path is down the steering shaft and through the u-joints filled with greasy needle bearings. clearances increase and the ground gets intermittent. hold down the horn button so the horn honks, turn the wheel, it stops for a moment and starts again.
206 637 4071
Old 09-16-2011, 05:16 AM
arbita1's Avatar
I had this problem and it turned out to be dirty connections on the horn relay. I cleaned the connections on the plug and relay and it fixed the problem.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-16-2011, 09:53 AM
tanmanbgoh's Avatar
thanks
forgot to mention is MOMO wheel, not original...
Old 09-16-2011, 11:52 AM
DRACO A5OG's Avatar
Momo ring hard ware should be the same for proper fitment. wiring may differ but not much.
'85 Carrera Targa
PCA/POC
Old 09-16-2011, 12:31 PM
Nine9six's Avatar
If its a Momo wheel, disassembly is simple and straight forward. Pull center cap and test the contacts per DRACO's posts. While you are in there you can also test for John Walker's suggestion as well.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-16-2011, 02:17 PM
masterdave's Avatar
+1 to everything said here, sounds like the grounds are intermittent, or there is an intermittent connection. I would check the connections at the horn as well things come lose. Use either high grit sand paper or NOXON the metal cleaner to shine every thing down to shinny copper. This has solved most my electrical problems in the past.
David Colangelo
"Porsche Accept No Substitute"
78' 911 Targa
88' 924s
31' Ford Model A
Old 09-16-2011, 05:23 PM
+1 on the horn relay
Scott
1984 Carrera 3.2 Guards Red
Old 09-17-2011, 06:19 AM
