Cleaning H1 headlights
Hi,
I got myself a pair of H1 headlights. One has cracked glass, and both need a good cleaning inside and out. My question is, "how does one disassemble the entire headlight?" I've removed the metal wire clips-no problem. I'm just wary about turning the screws located on the exterior of the chrome ring. Right now, I don't see a way to replace the cracked glass with somehow unscrewing the 'adjustment' screws. TIA, Brent PS, i've gone through my Porsche workshop manual and I can't find anything about removing the glass from the headlights.
Current: 1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun! 1971 911 T Targa Signal Yellow (summer joy) Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green |
Member 911 Anonymous
I have H1's with H4 lenses because I liked the look of the H4's. Yes I will go to Concours Hell.
If you removed the retaining clips, the back side should just lift off with out unscrewing anything. Just take care to catch the lens on the good one so it will not get damaged. The screws are just for alignment purposes, make sure the rubber ends are attached to the assemblies, if they are not, they will just spin and not adjust. Becareful of the coil adjusters, many of the H1's have broken or rusted away due to the PO over torque. Also notice where the copper strap are, they are your ground and must touch solid metal to insure lights will work. PM me if you have any questions. What I found is If you pre-align them to match it makes it easier to align them on the wall, 25 feet away and the same height of the center of the lenses. I also shoot the light on a side profile to see if the angle is staight & level. I highly recommend Daniel Stern's H1 Bulbs they are simply the best in that they completely fill out the ___/___/ pattern. All others have dead spot inclusing PIAA's.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 09-15-2011 at 07:43 PM.. |
AutoBahned
post a pic of your headlight, guts up
I can't remember how they come apart, but they do... I think you're right the long screws have to come off. I would soak the screws with a good penetrant, then be careful on removing.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
abides.
Once you've removed the wire spring clips, pull the adjuster tabs out of the rubber grommets. You may also need to unscrew the lower right adjuster screw (lower left as you look at the back side of the assembly. This will give you a little more slop.
The lens should now be loose, but still held captive by the chrome ring. Now, facing the assembly from the front, move the lens up and back, away from the trim ring, and rotate it. At this point you should have enough room to pull the bottom of the lens out the front of the chrome ring. I hope that makes sense.
Graham 1984 Carrera Targa Last edited by gtc; 09-15-2011 at 07:52 PM.. |
BTW, I got new H-1 lenses from Pelican Parts... They also had the screws that attach the chrome bezel to the body. It's been several years since I got these parts...
i got a spare H1 Lens too.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
abides.
Recently I noticed the lenses were down to $38 or so... a screaming deal considering they've been $60+ for the last few years.
... if that matters to anyone besides myself
Graham 1984 Carrera Targa |
Well, since I'm going to restore these babies, I see our host doesn't have "super white" bulbs available. Can anyone recommend another site? I hate to ask, but PP list them as NLA.
Also, I'm guessing that I should stick to 55W for the bulbs? If not, suggestions are appreciated. Brent
ASE Master Tech - 35 yrs
there was a nice article on cleaning 'em in October 09 Excellence titled "Got Milk?"
you should be able to get 100W bulbs from JCWhitney or any offroad performance place; or even your local FLAPS i got some recently
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
AutoBahned
don't waste $$ on "super white" bulbs
get relay, install & use good higher powered bulbs - Daniel Stern has it all worked out so search up his site |
