Old oil, how bad can it be??
I changed the oil in my 67S with Brad Penn last year, then life got in the way.. and I didn't get a chance to get the car out much. One run to a buddys place, maybe 15 miles.
So there's 15 miles on my 15 month old oil and I'm planning on taking the car out a few times this fall. So should I change it?
Thanks!
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 09-16-2011, 06:19 PM
retired mech eng
I would think the oil would be fine.
Old 09-16-2011, 06:20 PM
Really, it is no different than being in the can...it's just in your sump instead. Your car should still go about 300,000 miles if you use it! Nick
Old 09-16-2011, 06:24 PM
kilodawg's Avatar
I think it's the moisture that would be the major concern. I'm no expert but I've always been told 5K miles or 12 months.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 09-16-2011, 06:32 PM
the moisture condnesates in the engine and dilutes the oil. Its kinda open to the atmosphere so that may have an effect on it. Sitting in a bottle its sealed. Still 15 months I think would be ok. I wouldnt stretch it more than 20 months or so. Depends how it looks. If it gets funny looking kinda foggy and stale smelling change it
Old 09-16-2011, 07:31 PM
dshepp806's Avatar
Start fresh,..I'd load new stuff.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-17-2011, 01:29 AM
I have a few cars that seldom get driven my 911 included and I change the oil twice per year to just err on the side of "peace of mind". Personally if the oil looks like honey you are fine, but definitely change it after a few of your runs this Autumn.
Yasin
Old 09-17-2011, 04:14 AM
You would have been done already"
Go to the garage turn on the radio "
And get dirty ,,,
Old 09-17-2011, 06:48 AM
Drisump's Avatar
I hear the "oil is cheap but an engine is expensive" argument, but I'm of the belief that unless you left the car out for that period of time the oil is fine, after all you don't change transaxle oil every year regardless of mileage. The act of starting the car generates most of the condensation and if the engine is run a proper length of time, most of that moisture is vaporized, therefore a car that is stored in a decent place and not started won't build up a significant amount of condensation over 12 months. Cheers
Old 09-17-2011, 07:08 AM
retired mech eng
What he said.
Old 09-17-2011, 07:22 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Thanks!
I would run the car the "few times" you mention and then change it (hot) just before putting her away again to get rid of any condensation that may be in there.
Gary R.
Old 09-17-2011, 07:59 AM
Thanks for the reply's! Oil still looks good and green, I feel a little better now taking that drive this weekend.
Past:
Old 09-17-2011, 08:32 AM
AutoBahned
RWebb's Avatar
one drive won't kill it
Manf.s do shelf date their products, suggesting it will not last forever. Moreover, car makers tell you to change after a certain time (as short as 6 months for a mid-1980s VW Vanagon) no matter what mileage.
It is possible that over time, some things react either among themselves, or oxidize with the air. Or maybe small particles can settle out.
Buffers will not be loaded up with combustion acids, other nasties from combustion will not be present, the oil molecules will not break down from high heat near rings & valves, and as per above there will be little water in it. THO any water that IS in it will have had plenty of time to emulsify.
Yes, oil is cheap - that's the bottom line, no matter the quantification of the above parade of potential horribles.
Old 09-17-2011, 12:00 PM
Extremely toxic by now, so carefully drain into original bottles and mail to my address for suitable treatment asap.
Cheers,
Joe
Old 09-17-2011, 01:08 PM
RETIRED
Joe Bob's Avatar
Run it to operating temp. Pull the cap and look for mayonaise. If it's foaming at the mouth like Byron being offered a trade....you have excess condensation.
Otherwise drive it like you stole it.
BTW, you may have some excess smoke at start up....normal.
2012 ML350 3.0 Turbo Diesel
Old 09-17-2011, 01:11 PM
Burn the fire.
Brando's Avatar
+1, this would be the best thing to do. BP is good oil and should last a lot longer than the generic 'performance' oils at your FLAPS.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-17-2011, 01:53 PM
