911 Strut Brace
At this springs Hershey Swap I purchased what I believe to be a Weltmeister strut brace. It did not come with the mounting flanges shown in the picture below. Does anyone know if it is possible to but these separately?
Old 09-20-2011, 04:10 AM
Northern Motorhead
wildcat077's Avatar
Weltmeister sells them for something like $45-48 dollars a side ...
Call them,they should be able to supply you with new mounting brackets.I had called them last year because mine had cracked but i decided to weld them up instead !
There are a few posts where people cut out a hole (possibly 1 3/8) to relieve the shock mounting nuts on the brackets,do a search and cut the holes before you install the strut bar and get an alignment.
I will be doing this over the Winter when my car is stored away ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-20-2011, 05:18 AM
na2ub's Avatar
Yes, if you get the weltmeister, you must modify them to allow the top of the shock to pivot freely. These were incorrectly designed and crack because they clamp to the top shock bolt. Might as well look for a different design / manufacturer, and just make sure your bar will fit. Looks to be pretty standard heim joint end.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-20-2011, 05:29 AM
schumicat's Avatar
I think I have some spare brackets from a JM strut brace that you could have really cheap. PM me if interested and I will see if I can find them.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-20-2011, 06:01 AM
Max Sluiter
Flieger's Avatar
You could get a Rebel Racing one Suspension1
Or else make sure you modify the mounts on the Welty.
Old 09-20-2011, 09:01 AM
Capitalist and Patriot
911Freak's Avatar
Thumbs up
Anyone have any before and after pics of this modification?
My car came with the Welt. bar already installed. So I just want to make sure this modification has been done, and if it hasn't any insight on 'how to' would be great!
TIA
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 09-20-2011, 10:47 AM
na2ub's Avatar
I think you just have to hollow out / enlarge the hole that the center shock bolt goes through, so it is not attached to the mount at all. This bolt needs to pivot. The mount should rely on the 3 outer adjustment bolts for its "mount." This is probably why the OP found a bar with no mounts - the old mounts were proably cracked. Do a search and you will find more info on the weltmeister mounts, the cracks, the welds, and the mods. There are pictures available.
Check this out:
Weltmeister strut bars
Doug
Old 09-20-2011, 12:26 PM
Thanks for all the replies. Greatly appeciated. I am aware of the mod. I just couldnt locate a pic when I was posting.
Schumicat. thamnks for the offer. check your PM.
DRcoastline
Old 09-20-2011, 06:15 PM
