Static Timing 1970 T
I went through the procedure to static time my 1970 T. When I started the car and put the timing light on, The pulley mark for 30 degrees btdc lined up perfectly with the notch in the fan housing. What did I do wrong ?
Old 09-20-2011, 04:33 PM
Are you sure that you didn't rotate your dizzy by 180?
Not that I think static timing in these cars is ok but procedure is to set the pulley at 0 and then rotate the distributor until a test light just turns on. Then start car and test timing with a strobe light. I usually just test for full mechanical advance at 5000 and let the idle timing be whatever it turns out to be.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-20-2011, 04:46 PM
that's basically what I tried to do. When I moved the distributor to get back to Z1 the car runs irregularly and wants to die at idle. I figure that I must have something off in the basic set up.
Old 09-20-2011, 05:15 PM
