83 911 Production Cab #10
JJ 911SC's Avatar
Question Oil in the Air Intake Manifold
I’m sucking oil into the AIM through the 90 degrees rubber boot/throttle body via the Main Vent.
The oil level is at half way, line has a restrictor at the oil thank side and the rev goes down when the oil cap is removed.
I tested the restrictor and I was able to have air flow through the hose both way. While there is a small hole on the restrictor (pointing toward the tank) I did not feel any more resistance going from the tank to the boot.
Also, not necessary related but could be, when I turn the car off, it give a long depressurizing gasp...
JJ
Who Will Live... Will See
Old 09-19-2011, 09:39 AM
JJ 911SC's Avatar
Not really... Half way or below.
Maybe the restrict or is shut. I could not feel a pressure difference between one way (90 degree rubber boot to oil tank) or the reverse.
Old 09-24-2011, 04:57 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Check Valve.
If your oil level is 1/2 full.
This may be what you need.
Or this.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-24-2011, 06:36 PM
JJ 911SC's Avatar
Originally Posted by 86 911 Targa View Post
... Or this.
I got this one in the hose but I think its shut...
Old 09-24-2011, 06:54 PM
I would recommend doing a leakdown test to eliminate any chance of a mechanical problem causing this issue.
If that checks out normal, I'd review your tank vent plumbing and dipstick calibration (assuming its always at the halfway level when the engine is HOT).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-24-2011, 07:05 PM
JJ 911SC's Avatar
What would be the mechanical relationship?
More info (as usual)...
I had the engine out and every thing was clean when I put it back.
Unrelated, my VR when kaput 2 weeks later.
Since the damper bracket (Cabrio) would not let me do the easy swap, I end up removing the air intake, and access the back of the alternator after lifting the engine shroud (a real PITA, 5 hours to get there, 10 minutes to replace the VR and so on...)
I notice at that time that I had a line of oil coming down the Main Vent line on the 90 degrees boot. When I did a blow/suck on the line fitted with the restrict or, I did not notice any pressure change thus my leaning toward the restrict or being shut.
I triple check the vent pluming and never ran the tank above the mechanical half way point, with match the guage.
Cheers
JJ
Old 09-24-2011, 07:30 PM
Yes, Steve, I also would like to know what mechanical problem could cause oil to go through the oil vent line into the air intake? I have the same problem and would like to know what to look for.
Gary Kozun
83 911SC Cabriolet
Old 09-24-2011, 08:23 PM
Gentlemen,
Mechanical issues that will push oil into the intake system through the vent line are broken rings and/or piston issues.
This allows cylinder pressure past the rings and pressurizes the engine case & oil tank.
Leakdown testing allows one to see if thats the case by noting leak percentages on the guage and noting where its coming from.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-24-2011, 10:12 PM
JJ 911SC's Avatar
Originally Posted by Steve@Rennsport View Post
Gentlemen,
Thanks.
In my case I got a very well define line dripping from the boot as oppose to splashing.
Old 09-25-2011, 03:04 AM
T77911S's Avatar
Gentlemen,
this along with just plain ol worn out rings, like my car has.
are you checking the oil level hot?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-25-2011, 09:57 AM
JJ 911SC's Avatar
Yes, on level ground after a minute at idling. Half way on the stick and on the guage.
Its not coming from the engine as I can follow the oil trace from the back of the boot down the throttle assembly.
I'll be changing the in-hose restrictor as the air flow through the hose is the same either way.
Old 09-25-2011, 01:33 PM
